SOURCE: jenn-air jes9800AAB keeps buzzzing, front function panel flashes on and off
Your control panel is getting ready to quit. Mine did the same thing, I ignored it and now nothing on the touch panel works. About $150.00 for the part.
SOURCE: Jenn Air slide in range JES9750AAB - Touch Pad
put on tree belt . having the same problems replaced ERC $200.00 now they are telling me touch pad touch pad is $240.00 .the stove cost $1300.00. $1740.00 how much more will i have to put in this stove
SOURCE: jenn-air electric range model JES9800AAB some kypad # not working
Unless they start working again after it has a chance to dry out the touch panel will have to be replaced. This happens when excess moisture gets between the very thin layers of the membrane.
eric
SOURCE: I have a jenn-air 30 inch downdraft electric slide
I have 30 inch slide in Jenn air and the black top is blistering and peeling. Jenn air replaced it one but the same thing is happening again. What can I replace this with.
SOURCE: How to replace spark igniter - Jenn-Air SEG196 gas-electric range
took off the knob to the ignition system to clean and spray got onto the ignition under the dial and now the two front burners won't ignite unless I turn on one of the functional back burners then turn on the front burner. How do I repair this?
