SOURCE: I want to skype my
Try to delete cookies on your internet option, you can access internet option through Start->Control Panel->Internet Option. Under Internet Option just click Delete under Browsing History. After That try to reinstall the Skype.
SOURCE: Sound is very low in
Hi and welcome to Fixya!
If you're not computer savvy or you wanted the easiest way to solve this, call the ideapad warranty support on this number 1 877 453 6686.
They can control your machine remotely and solve the issue right under you're very eyes =)
Hope this helps!
SOURCE: lenovo z560 cpu overheating problem solved
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
SOURCE: nvidia driver not intstal in ideapad Z560 in Windows XP
Try to download again. delete corrupt file. Perhaps it was a "Hiccup" By the way you have a Lenovo IdeaPad Z560 didn't that come with Windows 7 64bit? Did you downgrade to Win XP SP2?
SOURCE: lenovo ideapad z560 I can't find my video graphic card installed
If you are using windows 7:1. Go to "Control Panel"2. Select "Display"3. Select "Adjust Resolution"
4. Click "Advance Settings"
a sub menu will appear wherein the details of your installed video card will be shown...
