SOURCE: Tec 572 printer gives "no ribbon" error with ribbon installed
You have to set the ribbon type to be "non-transmissive" for black transfer film.
To set the ribbon type, turn the printer off. Then press and hold the "feed" and "pause" buttons while turning on the power. The printer will now be in diagnostic mode - you can page through the menus until it says "ribbon type"
Pick the correct type and press the "pause" key to save the value. Then turn off the printer and turn it on again normally. The ribbon error goes away.
SOURCE: Ribbon Error
According to the user's manual this message indicates a problem with the ribbon sensor. As a test, set the unit for thermal direct printing and attempt to print a barcode. You will not see the code if yoiu are expecting thermal transfer, but the paper/label should feed like it is printing. That will indicate that the printer is functioning. At this point, the sensor needs to be replaced.
Hope this helps,
Dan
SOURCE: TEC SX4 Label printer received
How do you communicate with the printer?
If by serial check the speed parity etc frma the parameter menu
Else check that the character selecter for esc sequence is correctly programed els choose Auto.
TO en ter parameter settings
Switch on with feed and puase key pressed. When (1) diag V XX displayed press feed
(2) parameter is displayed.
With the pause button you can navigate in the menu and feed and restart allows you to change the value.
Else do a parameter clear to put everythig to factory defaults
SOURCE: barcode printer type: TOSHIBA SX4 sensor
Diagnostic boot
Feed PAuse button pressed and switch on Keep button prressed until message (1)Diag ...
with feed goto 5 sensor adjustements.
Pause to enter the menu
select the sensor you want to calibrate!.
Feed or restart button for 5 seconds until a star appears.
Switch off and on the calibration is stored in Eprom
SOURCE: Hello, I have a toshiba tec b-882 thermal label
The printer default is ribbon trans.
if your ribbon is too dark you should modify this option to ribbon no trans
