Screen has gone to minimum brightness and I cant adjust It back to a brighter setting
SOURCE: Screen Brightness gone too low on toshiba satellite 1110 laptop
Hello Tim,
Sorry to answer u by this news :
this problem u have happening by 2 cases ..
1st Case :::: that's maybe ur screen lamps is broken ..so u can see the data but very dark or no Back-light .. so u will need to replace the screen..or advanced option but with expret person to change the lamps from another broken sceen,,
2nd Case ::::: The high-voltage board..it's small board built below the screen to give the screen the right voltage to light on .. so u will need to replace it also ..or Advanced option also but with expert electronic person to check it ..
best luck.
SOURCE: Acer Aspire 5610 Laptop - dim screem
Holding Fn key down and press up arrow toturn up the brightness.
SOURCE: The screen brightness changes due to plug in or battery power
This is quite common actually I see it a lot. There really isn't any reason, it seems that when on batteries it trys to save power by Dimming Down, but it often just mucks up.. I always now set it via the keyboard keys. whenever I change from power adapter, to battery.
SOURCE: can you adjust the screen
Hello. yes. to adjust the screen brightness, go into the control panel and find the brightness or contrast adjustment. Joe
please rate my answer as 4 thumbs up. thanks.
