Literally won't fill with water until I turn on the dryer. Now it just fills with water and won;t run
SOURCE: No water is coming in the washer before the agitator starts
The most common cause of a washing machine not taking any water in is either a kinked fill hose or the tap becoming faulty whereby you switch it on but the valve inside doesn't turn. Another common cause is the tap getting accidentally switched off and people not realising. Other causes can be wiring faults, water valve faults or programme control faults. these days the vast majority of washing machines are cold fill only and should give an error code if they can't take in water.
Most washing machines are controlled by software programmes these days and produce error codes if they don't detect the correct amount of water has been taken in within a set amount of time. The error code for not filling should be mentioned in the instruction book
Washing machine making a humming noise when trying to fill?
If the washing machine wont take in any water at all, plus you can hear a humming noise (not normally present), check that both your taps are turned on, or that the water supply hasn't been cut off in someway. A gentle humming from the back of the washing machine could be the water valves being energised and trying to take water in.
If water comes through at a decent flow rate then check the filter in the water valve on the washing machine. You can pull it out with a pair of pliers and clean it. However, this will only explain your fault if it is severely blocked up, which is rare. Be careful not to damage the filter with the pliers as they are often delecate and brittle. If you create a hole in one - even a small hole - it can let grit and even small stones through into the water valve and damage it resulting in possible flooding in the future if an obstruction stops the valve shutting off properly.
No adequate water supply coming through the hose?
If no water comes through the hose, or the flow is very slow, then the fault is in the plumbing or there could be a kink somewhere in the hose. If your machine was plumbed in using those self plumbing taps that clamp on to the copper water pipes then they do sometimes get clogged up and need the hole clearing. If this happens to the cold supply it can be achieved by turning the stop tap off first, but if the hot supply is blocked - which is the most likely of the two - then you have to turn off the cold supply and then drain the hot water tank by turning on the hot tap until the water is drained out (unless you know where the valve is to turn the hot water off in your water cylinder).
If your machine is plumbed in using the ubiquitous blue (and red) levers to turn the tap on and off they can commonly go faulty where you think you've switched it off or on but only the plastic lever has moved and it hasn't actually operated the valve inside the tap. This is typically caused when the red or blue plastic lever cracks. You can usually operate the tap using pliers.
SOURCE: Washing machine Whirlpool Lsn1000pq1
My washer is doing the same thing. I put it up on blocks so I could see where it was leaking from. On mine it was leaking from the pump which a big white piece of plastic in front of the motor. The pump has two hoses connected to it the **** the water out of the tub and pump it out the drain hose. Disconnect the two hose clamps, remove the hoses (use force). There are two spring clips on top and one bottom. I laid mine on it's side to remove them. There two slots one top, one bottom for you to use when prying the clips off. Place screwdriver under clip and between grove and push/pull until they come off. Carry pump to the sink, fill with water and see if it leaks from somewhere, should be obvious.
SOURCE: washing machine starts filling then wont go any
there are a lot of questions of a simular nature check the diaphram switch this controls how much water is taken in and wont progress until the switch says so what you dont say is if the machine keeps filling or stops filling and wont progress
SOURCE: whirlpool washer model# WTW57ESVWO starts to
Hi, the water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
SOURCE: WASHER FILLS WITH WATER, THEN WON'T AGITATE.
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
