This refrigerator has a bottom freezer and there is a fan in the back of the freezer area that builds up ice and makes a noise that gets consistantly louder. We have to pull everything out and run a hair dryer over the back vent to thaw it out and then it is good for about 1 week when we have to repeat the process. Called Sears and their repairman basically said there is no fix for it. This refrigerator is only 3 years old. When it was first installed it was not cooling properly and the automatic ice maker just froze up. The repairman at the time said the thermometer probe was not pulled through the wall correctly and fixed that. Very unhappy that we spent over $1,000 and Sears is not standing behind this product.
SOURCE: water leeking on floor
most fridges and freezers have a small outlet hole at the very back of the inside make sure this is clear should have a small tub at the back of your appliance on the outside try this
SOURCE: freezer wall ices up, fridge not staying cool
Is it ice in the freezer or frost? snow like.. big difference in problems
SOURCE: Freezer stays cool but bottom stays warm.
I agree with your analysis, and recommend that you replace that fan between the two sections.
SOURCE: ice forming on freezer back wall of 6 year old top
u have a defrost problem unplug for 4 or 5 hrs with door open will work like new till u can get a tech out to replace parts
SOURCE: Water leaking into freezer
It may be the defrost thermostat. This thermostat turns on a heater in the freezer a couple of times a day and melts the ice in the freezer which should go into a tube that leads to a pan underneath the refrigerator, where it sits and evaporates from the heat of the compressor. It could also be the timer which tells the refrigeator to turn off a couple of times a day and tells the defrost thermostat to turn on.
