The bulb has blown on my Zanussi ZBF 360 Single oven. I have replaced the bulb a couple of times, but it blows each time I reconnect power to the appliance (i.e. flip the main trip switch). I've been using a 25w E14 as specified in the Zanussi manual. Each time I try, the bulb blows and trips the circuit breaker. Note: I found that the glass dome of some bulbs is slightly too long, thus preventing the protective glass dome from screwing into the fitting. Perhaps I used an unsuitable bulb 1st time I replaced the bulb? It's entirely possible that I have caused some permanent damage to the bulb holding fitting. I thought I had only used 25w bulbs though. Any ideas of how I can tackle this problem? Thanks, John.
Bulbs blow from incorrect voltage in use or loose ground wires ( arcing out)
if they fail while the oven is on it is because the bulb construction glass is wrong
bulbs used in ovens need a special heated treated glass and are generally only available from the service agent
failing immediately on turning on indicates a bigger problem that the bulb so call in an electrician to test the system
SOURCE: zanussi zbf260x built-in oven keeps tripping out
Probably due to a fault on the oven heating element. Check continuity and earth with a multimeter if you can but it's odds on you will need a new heating element.
