I need a cable to hook the E280 to my computer so I can load Mp3s, and photos. I lost the one that came with it.
SOURCE: I couldn't find Sansa on my computer when I connect with USB cable!
go into the Sansa m200 menu under Settings -> USB and select MSC instead of Auto Detect.
SOURCE: E280 and my computer do not connect
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
SOURCE: Computer doesn't recognize unit when connected
I have the same problem and it says that the device cannot start (code 10) when i look at the MTP devices listed.
SOURCE: Sansa e280 will only charge when connected to my computer
I'v had problems with my Sansa 280r (I think)... everything was working fine for about two years and then I recently tried adding a new playlist and everything went funny.. WMP would only see it in MCS mode and not in MTP which is the wrong way around and when I sync everything appeared to work fine until I disconnected it and there was nothing on the player. So I hooked it back up, tried sysc again but it said that all the songs were already onn the device yet it was still empty when I unhooked it.
I tried everything from uninstalling it in Device Manager to reformatting it but nothing worked... Looked for drivers on San Disk but there are none.
Anyway, I had actually given up and was looking at new MP3's on the San Disk site and I noticed a link to download WMP 11... I kinda thought I had that version already but rather than even checking, I hit the download button... My sansa has been 100% ever since... I reckon I must have lost or damaged some files or components and it was affecting how WMP was interacting with the SANSA.
If your having any problems with your Sansa, these are the steps I would try.
1) Put the device iin MCS mode (Settings/USB Mode/MCS)
2) Hook it up to your computer and double click 'My Computer'
3) The player should show up here as a drive... Right click and select 'Format' (Personally I used the long format... not sure why but it doesnt take long)
4) Disconnect the player
5) Download WMP11 and restart your PC
6) Change your USB mode on the player to MTP
7) Open WMP and connect the MP3... You should see it straight away as a new device and it will ask you to name it (Delete any old references in WMP that you used to use as this is a new "partnership" your setting up... Just right click the old name and select 'End Sync Partnership)
Hope this helps... If not you someone else somewhere... Pain teaches well !!!!!
Shay Murray
SOURCE: Sansa Sandisk e280 8 GB - USB not detecting on my laptop
up until very recently i had the same problem, found this review through alot of google searches and it seems to solve the problem. must stress i cant take ANY credit for solving the problem but if anyone meets this guy, tell him i owe him a beer.
http://www.amazon.co.uk/review/R1PE6Y4WT1FL0E
