SOURCE: Date/time change
Press program
then 0
(this will then display current date and time - overtype as follows)
eg. for Friday 2nd November 2007 8:58 am you type the following
071102 (date backwards) [space] 5 (Friday is 5th day of week) [space] 0858 (time) [space] 0 (0 is am, 1 is pm)
Press the store button and then program button to exit the programming.
SOURCE: Panasonic KX-T7730 Corded - change display
On mine I press the asterix to toggle display options
SOURCE: Panasonic KX-T7730 corded
If you can provide the phone system type I will try to help as this is a system wide setting and there are a lot of different Panasonic systems out there. ......Mike
SOURCE: Change the time and date on Panasonic KX-T7730
You have to change from extension 101. Once you are on extension 101 then you need to press program then 0. enter date backwards ie(081104) then day (1=mon 2=tues 3=wed 4=thur 5=fri ect.) then enter time ie(0300 for 3:00) then 0 for am or 1 for pm. so it would go like this
Press program then 0
Enter (example for Tues. Nov. 11,2008 3:00 pm) would be
081104 2 0300 1
then press store then program again and it's set.
SOURCE: Panasonic KX-T7730 - changing time display
Following are the steps:-
PRESS: - PROGRAM (PITS PGM NO. APPEAR)
- *#1234
- 000
- Speaker (Date/Time will appear on the screen & blink
- Point directional sign to the desired position to change accordingly
Once finish with the above - Press "STORE" button
Then lift handset and replace
MT
