Click this link for instructions
http://www.fossil.co.uk/wcsstore/CommonFossil/attachments/watch_instructions/Fossil_Watch_Instructions_ENG_UK.pdf
Press the "Mode" button on the lower left-hand side of the watch twice to change the time.
Press the "Start/Stop" button on the upper right to select the hour, minute and second in setting the time. Also use this button to select the date.
Press the "Spl/Reset" button on the lower right side of the watch face to change the number for each selection.
Press "Mode" again to set the time.
Please let me know if you should need an further information. If you find this helpful, please remember to rate it.
Enjoy your watch!
--Sandy
To set the time on your Timex 1440 Watch, please follow these directions:
1. Press and hold MODE (Upper left button)
(HOURS will flash and you'll be in Alarm Mode).
2. Press MODE again to enter TIME mode.
(SECONDS digits will flash.)
3. Press ADJUST (bottom right button) to set SECONDS to zero.
4. Press START/STOP (upper right button) to select MINUTES
5. Press ADJUST to change
6. Repeat to set Hours, Date, Month, and Day of the week.
(Go through 12 hours to set AM or PM)
7. Press MODE when finished
8. To display DATE from TIME display, press START/STOP
9. With DATE displayed, press and hold START/STOP, then press ADJUST to change display between DATE-MONTH
10. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12 and 24 hour format.
I hope you are now able to set the time on your watch! If you appreciate these instructions, please remember to rate this post.
--Sandy
