20 Most Recent Dakota 2786-6 Wristwatch Questions & Answers
Watch battery number for dakota watch
This watch requires a size 1620 battery, available at all Dakota Watch Company store locations, and most electronics stores. Dakota Watch Company always recommends taking your watch to one of our store locations or a reputable jeweler to reduce the risk of damaging your watch during a battery change.
We are sorry to read of your trouble with receiving technical support. We will be happy to answer any questions regarding your Dakota watch. Please feel free to contact our Customer Service by email at [email protected], or by phone at 1-888-459-0404. Thank you!
8/17/2015 11:44:29 PM • Dakota 2786-6... • Answered on Aug 17, 2015
0answers
Just purchased a dakota watch
can you pull the minute meter and rotate it on either direction? (clockwise / counterclockwise). Sometimes its stuck if the device was stored in a cold temperature. Otherwise you may go back from where you bought it for assistance..
9/4/2011 7:38:48 PM • Dakota 2786-6... • Answered on Sep 04, 2011
0answers
Where can I get the instructions to set my
Browse through my tips, please. There are plenty of watch manual links.
8/5/2010 3:32:29 AM • Dakota 2786-6... • Answered on Aug 05, 2010
2answers
We replaced the battery and
One needs specific equpment to be able to trouble shoot this kind of watch. Most of the time, the problem will be related to dirt, dust, oxidation, and occasionally, battery corrosion. It can also be a cracked solder connection. If you are getting a display, then the problem will be with a push button switch. This could possibly be cleaned with electronic contact cleaner, just let it dry thoroughly after cleaning it.
To verify radio control, one actually needs at least an ocilloscope, that usually only a repair facility would have. However, there is a procedure for solution for setting the time from another Fixya expert, and here it is:
Best Solution posted on May 21, 2009
noavatar_s.gif Dakota CS
Rank: Apprentice
Rating: 96%, 7 votes
When changing time zones, your watch must be manually set for the new time zone you will be entering. This watch is not designed to adjust for new time zones automatically. Instructions for changing time zones can be changed using the directions found on pages 2-4 in your instruction manual. When changing to and from DST, your watch should automatically adjust for this difference with the next 24 hours after the change. If your watch has not adjusted, you may be in an area that is not receiving signal. Check if your watch has received signal by using the directions found on page 1 of your instruction manual. If your watch has received signal in the past and no longer is receiving signal, your watch may need to be serviced or exchanged. Please contact Dakota Watch Company Customer Service by email at [email protected], or by phone at 1-888-459-0404. ******************************** Good luck, and hope this helps.
7/29/2010 2:47:46 AM • Dakota 2786-6... • Answered on Jul 29, 2010
What battery does this take and do I need to take
mcdevito75 here, BEST BET, look for a small watch repair shop in your area for this Battery change.
7/27/2010 12:26:26 AM • Dakota 2786-6... • Answered on Jul 27, 2010
4answers
Dakota atomic wrist watch sold by National geographic
s1 is the top button and s2 is the bottem button
11/6/2009 6:59:16 AM • Dakota 2786-6... • Answered on Nov 06, 2009
Lose or gain time?
We are sorry to read of the trouble you have experienced with your Dakota watch. The problem you have described is typically a mechanical issue that requires a movement overhaul completed by our repair department. Depending on the details of your purchase (date, place of purchase, receipt, etc) this service may be covered under warranty. To determine how to submit your watch for repair, please visit your nearest Dakota Watch Company store location, or contact our Customer Service by email at [email protected], or by phone at 1-888-459-0404. Thank you!
5/21/2009 3:16:19 PM • Dakota 2786-6... • Answered on May 21, 2009
I purchased a Nat. Geo. Dakota watch in past
5/21/2009 3:03:51 PM • Dakota 2786-6... • Answered on May 21, 2009
0answers
Changing digital watch from 24hr time to am/pm
Press & hold the "MODE" button.
3/4/2009 9:29:37 AM • Dakota 2786-6... • Answered on Mar 04, 2009
I cannot get to the battery,even with back plate off??
That additional layer actually is the +contact. Take an eyeglass and follow-up all the way to that contact into the movement till you find the small plastic hook (hooks) it is clamped on. Get the fine pointed tweezers and undo the contact by pulling the contact end outwards from the hook. The contact should release the baterry. Memorise the writings on the baterry and buy exactly the same one.
Do not forget to rate, please.
2/28/2009 3:45:22 AM • Dakota 2786-6... • Answered on Feb 28, 2009
Dakota 2786-6 Wristwatch Logo
Popular Tags
31 questions posted
Top Dakota Watches Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Paul Katynski
Paul Katynski
Are you a Dakota Watch Expert? Answer questions, earn points and help others
View Most Popular
Dakota Watches
  • Dakota Watches
Most Popular Question
get instructions set
  • Watches
