Was not running in accudry mode,run,drys timer never moves to shut off.
SOURCE: whirlpool dryer: supreme Not heating up
Hi thanks for the question. the problem could be the thermal fuse located at the back . remove back panel. on the air duct . a small piece of plastic with 2 blue wires to it . replace the thermal fuse thanks .the appliance doc
SOURCE: Whirlpool Dryer
NEED A NEW TIMER NOTHING YOU CAN DO ABOUT THAT
STEVE'S APPLIANCE
516-300-3249
SOURCE: The timer doesn't work
If it is an electro-mechanical timer, then only solution is to replace same.
If it is electronically controlled, then problem is probably due to faulty board, again, it means a replacement being fitted.
Please rate my solution.
Thanks.
SOURCE: the dryer runs and drys clothes but there are
your timer sound like it stalling and replacement would be in order if if its in good shape buy one
SOURCE: Dryer not heating and timer dosen't move
A dryer runs 2 halfs (one half 120, the other 120). Sounds like you are missing the 120 that operates those two. Did you change from a four prong to a three prong?
First try cleaning the moisture sensors with rubbing alcohol,
these are two silver colored strips located inside the drier just below the
lint cleanout
