20 Most Recent Kenmore 800 6983 Electric Dryer Questions & Answers
My dryer shuts off before its time and not heating
Model? On a model I just repaired here's what I found: Model: 110.69422801 Kenmore Electric No heat. although sometimes it had heat for a short time. Suspected that the heating element was faulty (i.e. cracked heating coil). Nope. Checked hi and lower thermostats and both were good. Took apart timer controller. Found that the contacts inside were worn/burnt. Item is designed to fail. Slightly bent one of the contacts to make better contact and it is working. Ordered new timer/controller ($45 including shipping from "One Appliance" on line). Easy to replace. ALWAYS disconnect the power when servicing!!!
7/18/2016 6:50:27 PM • Kenmore 800 6983... • Answered on Jul 18, 2016
The dryer will only run when put in the 70 minute position
the timer mechanics inside has a problem with the switching and it needs a new timer clocked control look too ebay for one cheep
12/5/2014 1:59:40 PM • Kenmore 800 6983... • Answered on Dec 05, 2014
Wont start
Check the door switch. You should hear a click when you push and release it. If you don't, you will need to replace the switch. Here is the switch to order.Post back your results.
11/11/2012 2:42:36 AM • Kenmore 800 6983... • Answered on Nov 11, 2012
Need to change plug to a 4 wire
RED and BLACK from cord go to each outer terminal on the terminal strip block(they can go on either outer terminal as its A.C.power and not polarity sensitive),the WHITE wire from cord goes to the center terminal between the RED and BLACK wires,and the GREEN wire goes to any metallic portion on the dryer case for the safety ground circuit
5/6/2012 12:07:56 PM • Kenmore 800 6983... • Answered on May 06, 2012
Hello. I'm looking for
Hi dswooldridge...
Give a phone call to this parts house, they may have what you need.
www. partselect.com
1-888-895-1535
You can also go to the sears website and they have a phone number there, and also a parts search:
http://www.searspartsdirect.com/partsdirect/contactus.pd
Please take time to rate me
9/3/2011 7:31:30 PM • Kenmore 800 6983... • Answered on Sep 03, 2011
My series 80 Kenmore dryer won't start
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
8/5/2011 11:19:56 PM • Kenmore 800 6983... • Answered on Aug 05, 2011
Kenmore dryer 80 series wont heat. what to check
Hi rmalone0929...
Here are a few things to check:
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor/thermal fuse as it is faulty.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,
then you do not have to tape the wires together as described above.
To test your thermostat/thermistor/thermal fuseremove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace a generic element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please take time to rate me
6/28/2011 2:59:08 AM • Kenmore 800 6983... • Answered on Jun 28, 2011
Motor inop 3wires going into winding coil all have
you will need to pull the top back panel off the dryer, in the left hand upper corner there should be a booklet that has the wiring diagram, but without being there and having voltage at the motor and it not working then I would say yes it needs a working motor, eBay is probably the cheapest unless you know of a appliance repair shop, as they will sell used motors as well. Good Luck Tim
5/11/2011 11:35:47 PM • Kenmore 800 6983... • Answered on May 11, 2011
Drum truns no heat. circuit breakers ok
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
3/5/2011 1:14:41 AM • Kenmore 800 6983... • Answered on Mar 05, 2011
Dryer will run then shut off after a few minutes,
venting issue, thermostat, or thermal fuse:
http://www.applianceaid.com/general.html#vent
2/17/2011 12:56:24 AM • Kenmore 800 6983... • Answered on Feb 17, 2011
2answers
How do I get to the heating element?
Not sure on your particular model but most, that I have replaced, are accessible from a back panel. Hint: Before you start... use a camera (digital) to record your steps, so rebuild becomes easier. Also to the preventive maintenance while you are taking things apart. disconnect the exhaust, unplug the unit, clean all parts of lint, and finally check the belt. A DIY person can handle this task. Also before you begin check for the availability of the replacement element, which will give you some hints as to its installation.
2/9/2011 10:11:08 PM • Kenmore 800 6983... • Answered on Feb 09, 2011
I need to replace/test the
Since you have got that far... stop for a moment. Take a few photos of what you are doing, to help you rebuild the unit. You can test the motor without taking it all apart. Does the drum turn, by hand, relatively easily? If so, Good!
Does the drum turn when you start the dryer (I use the cold air setting for these tests)? If so, Good!
When you start the dryer (on cold air) do you hear the sound of the motor, but no drum rotation? If so then it maybe that the motor is good but the belt is broken or has frayed and is slipping; then the belt needs replacement.
Disconnect the dryer exhaust hose.... When you start the dryer (on cold) do you feel any air movment from the exhaust? If so then I think it is just the belt not the motor. If no air movement then it is probably the motor. A replacement motor cost approx. $165.00.
2/8/2011 3:18:41 AM • Kenmore 800 6983... • Answered on Feb 08, 2011
Electric dryer turns on but wont heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
1/15/2011 4:05:12 AM • Kenmore 800 6983... • Answered on Jan 15, 2011
We have a 80 series elec. dryer, today when the
Push the timer to a definate off position. Close the door. If it buzzes then more than likely you are getting power from the timer which could mean short in the timer. If you have the model # the parts places can easily find your parts.
12/28/2010 11:53:54 PM • Kenmore 800 6983... • Answered on Dec 28, 2010
My electric dryer acts like
check the cercket breker
and check the power by avometer . it has power check the bower in the dryer and fuses
9/24/2010 12:25:41 PM • Kenmore 800 6983... • Answered on Sep 24, 2010
My Kenmore 80 Series electric
Hi, their is 2 possible cause the first and most likely cause is going to be the belt is slipping and getting hot and causing the smoke, this could be due to the belt being loose or the drum bearing may be seizing and could need replacing. try turning the drum by hand to see how easy it is.
now the second problem could be that the motor is over heating due to the drum bearing failing or even the motor itself failing, see how easy it is to turn the drum if its quite easy and feels smooth then the chances are the belt needs replacing, if its stiff to turn or feels rough then this could be drum bearing or motor failing.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
9/11/2010 6:24:03 PM • Kenmore 800 6983... • Answered on Sep 11, 2010
Kenmore 800 6983 Electric Dryer Logo
43 questions posted
Top Kenmore Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
View Most Popular
Kenmore Dryers
  • Kenmore Dryers
Most Popular Question
dryer will only run when put in 70
  • Dryers
