The soap dispenser will not close at all.
SOURCE: Latch cover on dishwasher soap dispenser no longer functions.
hello there. i hope i can help you?. please check the latch spray a little wd40. and give the soap dispenser. a good clean with warm water. please check that you are useing the correct soap? as this can cause alot of problems. check once a week.top tip give the machine a good clean once a month. i hope this has helped you marymena? also please check for any little obstructions.
SOURCE: Our Frigidaire Ultra Quiet II dishwasher loud buzzing noise- wash
No longer "ultra quiet" huh?
A sound during certain cycles indicates a broken part. By the information provided sounds like a pump may be the problem. You may need to contact a service tech about this issue. If the appliance still under warranty, the service should be provided for free.
Every time when you hear noises (other than the normal ones) in the appliance, it indicates there is something wrong and it will worsen over time, so as soon you hear something is not ok, get assistance.
SOURCE: Frigidaire fdb510lcs0 soap dispenser not opening
Hi
Many dishwashers (but not all) use a BI-metal strip that heats up once poweris applied to it. The BI-metal strip bends and allows the soap door spring toopen up the dispenser. This bi-metal strip is not given full 120 volts power,the timer "shunts" the power through either the heating element (most common ) or the motor and this gives the bi-metal strip lower than fullpower to work and open. Most often the bi-metal strip has lost its ability tobend properly and needs to be replaced. Older GE dishwashers used a mechanicalarm driven by the timer to open the dispenser = no electrical bi-metals.
Newer Frigidaire dishwashers and many newer Whirlpool dishwashers use a wax motor to open the soap dispenser. The plunger insidethe wax motor slowly moves and pushes the plunger and door open. And, if thiswax motor doesn’t receive 120 volts, then it’ll not work.
This will help you --
Please do rate this solution and revert for furtherassistance.
Thanks
Rylee
SOURCE: Won't turn on. Frigidaire, precision wash, ultra quiet 1
I have the same issue and it occurred around the same time as your post. Do you think there is a conspiracy? :-)
SOURCE: my frigidaire ultra quiet spray arm doe's not
water does not spray on the top arm until a later cycle...only one arm spins at a time... a fridgidare thing
