Carried out cleaning process 10 times, won't print blue at all
SOURCE: Brother MFC 425CN will not print black
Have a look at the bk cart. Did you fix it well into position by clipping the support above the cart?
Can you see any difference by ink fuel before and after cleaning cycle? If there is no difference the valve is not open: drill a hole into the top cover and leave it open. Try another cleaning cycle again.
SOURCE: black ink is not dispensing
There may be an air bubble in the black tubing, it will take several more cleaning cycles to clear. You can tell it to clean only the black and save the other inks.
SOURCE: brother mfc-5490cn will not print black. Has new
If you've already run the cleaning cycle that many times without success you probably have to replace your print head. The best thing to do is to take the printer to a Brother repair center and have them give you a quote. Quite often it is actually cheaper to replace rather than repair.
SOURCE: brother mfc-215c unable to clean?
I have the same problem my printer (a MFC-215C) is unable to clean and when I press Menu/set I do not have "Black print"? So what do I do now?????? HELP... Thanks Nathalie
SOURCE: brother MFC 465CN won't print due to "Unable to
Hi Good day!! try this method
1.pull out the AC plug
2.put back the AC plug while holding down the "menu" button and keep holding it (15 sec)
3.now you are entering the MAINTENANCE mode and "error 46" pops up in the display
4.select 8 by using the arrow buttons ,push OK and select 0 and push OK
5.00:00 00:01 OK (the display is showing this message)
6.now push the MONO button 25 times until you see PURGE: xxxxx
7.Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
8.the purge counter indicates now: purge: 00000
9.switch off the printer ,switch it on
ready to print
