Wharfedale LP160DTRHDMI Logo
A
Anonymous Posted on Jan 31, 2013
Tv won't power up straight away - Wharfedale LP160DTRHDMI
Michael Hague
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 16, 2015
Michael Hague
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
270
Points
When lcd tv`s fail to power up, but stay on standby. It is usually because of bad capacitors on the power board. My 22" lcd monitor did the same. It would not come off of standby. It starts with them being slow to turn on. "Sound familiar"? I fixed mine by changing the bad caps. There were two of them.
Won't start!!!!!!!
Is there fuel in the tank?
Sylvania 32 inch LC320ssx
It seems that the set itself changes inputs. Place it remote control away from the vicinity of the tV. and check. If it does the same, do a hard reset next. To make it a hard reset, unplug the TV from AC mains wall socket, and replug it back after 10 minutes or so. If these do not help you, be sure that the main system control memory IC to it is faulty and should be replaced.
I've owned for approx 3 yrs. Today I was watching a show on my Panasonic TH-50PZ80U and all the sudden the sound went away. From the lowest volume setting to the highest, no noise at all...Please...
Hello!
First move: unplug your broadcast provider's box, wait for a minute, then plug it back into power source. I mean: leave all the connections intact, just unplug from power source. It might be just power cord or power adapter. If that's not the case, please do the same with TV. Unplug it from wall outlet, wait a minute, plug it back in. It's a next step, if your "box" won't take care of the problem. If that won't take care of the issue, refer to owner's manual for "reset" procedure. Worst case scenario: you might need to replace main board inside or your TV.
good luck,
Thanks,
Alex.
7helpful
My nokia e7 won,t turn on. Worked fine when i put it on charge the night before and the next morning the screen was blank and i didn't managed to get any response out of my phone
I had the same problem with my E7, if you've already tried holding the power button down for 10 seconds then you'll need to remove and replace the battery, that fixed mine straight away. Just follow the guide below
I rescanned the channels after our area has gone digital and this went OK but now the TV won't come on and the standby light just keeps fashing as though its trying to come on. I left it all last night...
You did the opposite of what might be useful. Completely cut of it's AC supply, pull the plug out of the socket and leave it like that for 10 minutes.
Plug back in but first making sure the manual power button is off on the set, not in standby mode.
(pushed in)
Then push the manual button to restore standby mode and switch set into full on mode with the remote.
It will either have "rebooted" and work straight away or you'll need to put it into Auto Set Up mode.
Proceed as the first sections relevant from the instructions.
1helpful
My 5 WEEK OLD nokia e63 won't turn on. the d-pad lights up along with the screen (black) but it won't do anything else... HELP!
This is easy ... it is still under warranty ... take it back ... do not do anything to it as you will void your warranty.
Take it back straight away and have it repaired or replaced.
Simple
Thank you for your interest in FixYa.com
Aug 26, 2011 • Cell Phones
System won't start and don't have recovery disc
Hi
you could try this
press the power on key
then straight away tap the alt tab bottom left along with the F10 tab top right
so its
power on
Alt+F10
this will hopefully take you into the factory recovery options
and choose what you want to do
then follow on screen instructions
hope this has helped you
please let us know if it did or didnt
so we may be able to help others
many thanks
1helpful
My brother's PS3 on my non-HD tv. We tried connecting and getting different S-video cables but it still won't show up anything. We know the input channel is correct, it just won't show. My...
Yes the display settings need to be reset since he had HDTV and you don't. I do this by simply having the PS off then press power button and hold it for 5 seconds.
1helpful
My daughter put the blue ray DVD into the Toshiba 14DLV75 instead of the regular DVD and now it won't eject it. It just keeps spinning like it wants to eject, but won't. How can I get it out?
Hello
Just switch OFF the set by its front panel power control switch, and then switch it On and press the eject button without any delay. Sometimes the tray will eject, and try to close. If so switch OFF the front panel power switch, while it is out, and take away the blu-ray disc. the switch it On. All will be ok then.
I have bought an optical fibre cable to connect from my jamo a305 to my new sony nx810 tv and im getting a buzzing sound, there are 2 optical fibre outputs on the back of the amp, which one do i connect it...
Have you looked at the manuals?
http://www.retrevo.com/search?q=sony+nx810
A TV won't run external speakers directly. Besides, the TV-related audio should originate at, say, the cable Box, and go straight to your (presumed) AV receiver for the best possible decoding and reproduction.
Buzzing is an analog phenomenon and is NOT carried by optical cable in any case.
Buzzing is usally AC line noise leaking into an un-shielded cable somewhere or a floating ground. If the AC plug is reversible, try that. Sometimes the buzz is from an attached device. Make sure all audio cables are plugged in tightly at each end and routed away from or at right angles to any power cords and away from other sources of strong magnetic fields like TV's. I've also seen variable track lights induce noise but it's usually minor.
Try rotating the power cord in the wall outlet.
If it still buzzes with no cables or anything external attached there's an internal problem.
Disconnect the input(s) and see if it hums in the absence of an audio source. A bad audio cable shield or unwisely-routed audio cables will allow entrance of unwanted signals from external power sources, magnetic fields, even dimmer-controlled track lights. Sometimes, simply reversing the orientation of the ac power plug can eliminate humming.
Reverse the cables Left to Right to see if it stays with the cable or the input channel. Follow it back to the source, isolating in the same manner. Eventually you will find the entrance point of the hum. Frequently a cable's ground will oxidize over time and simply removing and reattaching the cable with a twisting motion will re-establish the shield.
Top Wharfedale Televison & Video Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Steve Pack
Steve Pack
Are you a Wharfedale Televison and Video Expert? Answer questions, earn points and help others
