20 Most Recent Jamo A 305 Main / Stereo Speaker Questions & Answers
I have bought an optical
Have you looked at the manuals?
http://www.retrevo.com/search?q=sony+nx810
A TV won't run external speakers directly. Besides, the TV-related audio should originate at, say, the cable Box, and go straight to your (presumed) AV receiver for the best possible decoding and reproduction.
Buzzing is an analog phenomenon and is NOT carried by optical cable in any case.
Buzzing is usally AC line noise leaking into an un-shielded cable somewhere or a floating ground. If the AC plug is reversible, try that. Sometimes the buzz is from an attached device. Make sure all audio cables are plugged in tightly at each end and routed away from or at right angles to any power cords and away from other sources of strong magnetic fields like TV's. I've also seen variable track lights induce noise but it's usually minor.
Try rotating the power cord in the wall outlet.
If it still buzzes with no cables or anything external attached there's an internal problem.
Disconnect the input(s) and see if it hums in the absence of an audio source. A bad audio cable shield or unwisely-routed audio cables will allow entrance of unwanted signals from external power sources, magnetic fields, even dimmer-controlled track lights. Sometimes, simply reversing the orientation of the ac power plug can eliminate humming.
Reverse the cables Left to Right to see if it stays with the cable or the input channel. Follow it back to the source, isolating in the same manner. Eventually you will find the entrance point of the hum. Frequently a cable's ground will oxidize over time and simply removing and reattaching the cable with a twisting motion will re-establish the shield.
5/2/2011 10:29:09 AM • Jamo A 305 Main... • Answered on May 02, 2011
My Jamo 360 subwoofer is not turning ON. Last time I use it its all fine. I changed the 1 amp. fuse at the back near the 220 input socket because the fuse is blown. But it did not fix the problem.
Power supply inside has been damaged and is in need of fault dfinding and repair. Take it to a repair shop.
4/17/2022 6:24:19 AM • Jamo Audio... • Answered on Apr 17, 2022
I don't find JAMO D 5 SUB specifications ...please,help...
https://www.jamo.com/products/d500sur
2/21/2022 12:48:57 PM • Jamo Audio... • Answered on Feb 21, 2022
How do you pair a wireless Jamo 360 sub to sound bar.
You will just need to re-pair it. That is assuming the new board fixed the issue. https://www.fixya.com/support/r26362721-pairing_bluetooth_devices and also https://www.google.com/search?q=pair+a+wireless+Jamo+360+sub+to+sound+bar ..
12/22/2021 12:05:17 AM • Jamo Audio... • Answered on Dec 22, 2021
2answers
How do I deactivate the amplifier circuitry protection for a Jamo avr 793
It's problem come on due to a fault on the speakers or wiring or connections especially shorts! Clear that and it should come back on. If not then you have a fault in the main power amp section.
11/27/2021 9:56:25 PM • Jamo Audio... • Answered on Nov 27, 2021
2answers
Jamo sub 660 wont come on
Hi,I have the Jamo sub 660 and it won't come on,I took it to my technician,and he told me that it has a broken ic,the broblem is that he cannot replace it cause the number on it is scratched,does anyone know what the number is pls! Thanks in advance Joseph
9/27/2021 8:25:35 PM • Jamo Audio... • Answered on Sep 27, 2021
Pls help my jamo 210 sub does not swich on, where do i find the fuse
The manual doesn’t show a user replaceable fuse are you plugged into a house outlet or a power strip. If power strip confirm that power is present and try another slot to plug into. https://bcc2479de3c817356f4e-1bbe459354cb22c942d9efbc3d6dacbf.ssl.cf2.rackcdn.com/product-manuals/SUB210_OM.pdf
12/22/2018 4:53:58 PM • Jamo Audio... • Answered on Dec 22, 2018
I bought a jamo c80 sub with no power, its power supply dead. can someone guide me with the schematic diagram
Did you google it. Google, c80 sub woofer schematic, then look at images.
11/4/2018 5:33:16 PM • Jamo Audio... • Answered on Nov 04, 2018
Looking for a tweeter for jamo e370 floor stand speaker
Sorry we are not in the parts business.
9/5/2018 4:46:14 PM • Jamo Audio... • Answered on Sep 05, 2018
Jamo A 305 Main / Stereo Speaker Logo
1 questions posted
Top Jamo Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a Jamo Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Jamo Audio Players & Recorders
Most Popular Question
bought optical
  • Audio Players & Recorders
