SOURCE: Cartridge errors on HP97 / bad TSR?
Hi Scott -
Sorry, I do not have any additional ideas as it seems you have checked things I would have suggested - cleaning the contacts. (I presume you did clean the cartrdige contacts in addition to the printer contacts.) The TSR may be correct but may be encoded incorrectly, which could cause an issue as this would make the printer "think" the cartridge was too hot or too cold. The printer will refuse to print with certain ID errors. A 10-tap will bypass this test as a diagnostic aid. Does the 10-tap show a "good" nozzle diagnostic? If there are repeating missing nozzle segments across all three colors it would indicate an interconnect issue.
If the cartridges are original HP cartridges I would check the warranty date (two years warranty from date of manufacture) as shown here. If the cartridges are still in the warranty period contact HP for replacements.
Regards,
Bob Headrick, MS MVP Printing/Imaging
SOURCE: incompatible print cartridge tri color error
There may be debris that is blocking the communication between the cartridge and the printer. Remove the cartridge and unplug the printer from the power supply. Take a little bit of rubbing alcohol on a cotton swab and wipe off the contacts on the cartridge as well as the contacts inside of the printer. Allow both to dry for a few minutes before plugging the printer back in and re-installing the cartridge. This should clear up any miscommunication between the two.
http://swapink.com/Merchant5/merchant.mvc?Screen=cp_faq&Store_Code=SI
SOURCE: Pen in chute 1 has tsr failure.
Your black ink cartridge is bad.
Pen = ink cartridge
chute 0 = color cartridge holder
chute 1 = black cartridge holder
tsr = Themal sensor resistor
