Sony VAIO Notebook Logo
Anonymous Posted on Jan 26, 2013
I tried to connect my vaio to wifi it is showing limited axcess what should i do
Its not connecting to any wifi it is taking soo much time
Anonymous
Level 3:
  • Sony Master 32,281 Answers
  • Posted on Jan 26, 2013
Anonymous
Sony Master
Level 3:
Answers
32281
Questions
Helped
7913484
Points
102259
Limited connectivity
If you get a 'Limited connectivity" on you wireless connection on your laptop, it means that the wireless card on your laptop probably did not get an IP address from the wireless router.
To fix this problem, right click on the wireless icon on the Task bar and then click Repair.
This will force the wireless router to issue a IP address to the wireless card on the laptop.
3 Related Answers
jose_v17
Jose Velazquez
  • 229 Answers
  • Posted on Mar 26, 2009
SOURCE: Vaio notebook model PCG-6-W7P wifi internet connection
It maybe the driver for the wireless utitility that runs the card or the driver for the card itself. I would go to so download the latest and see if that fixes it
Anonymous
  • 558 Answers
  • Posted on Oct 12, 2009
SOURCE: Having trouble connecting Vaio to ethernet cable.
Have you restarted the computer?Reset the Router .Once this is done try again.
Good luck
Anonymous
  • 18 Answers
  • Posted on Jan 15, 2011
SOURCE: Sony Vaio netbook will not
That's usually your router, not the computer. Sounds like your computer is connected to your router, but IT is not connected to the internet.
I would suggest shutting down the computer, shutting down router, then the modem, plug the modem back in, waiit for lights to finish blinking (should be within a few minutes) then your router, once that's finished blinking, then turn on your computer.
1helpful
My Dell laptop will only connect to public WiFi with limited connectivity
Follow the following steps to resolve Wifi issues on your Laptop. Open Control Panel - Select Network and Sharing Center - Manage Wireless Networks - Highlight your Wifi Network - Right Click and Remove. Reset the TCP/IP stack of the windows system with limited connection status.
My laptop is showing limited Internet access over my home WiFi - Quora
https://www.quora.com/My-laptop-is-showing-limited-Internet-access-over-my-home-W...
When playing a show through my laptop to the chromecast it is all jumpy
Hi, this depends heavily on your Wifi network speed, try with a lower resolution/quality show, and see if you get the same effect. Keep in mind that your wifi network's bandwidth is a bit low for full HD quality.
You can also try to limit all other activity on your network by turning off the wifi connection on other mobile devices that is connected to your network.
Wifi says limited connectivity
Visiting the trouble shooting guide at the manufacturer's website is always advised.
Why can't i connect to wifi
not to be mean but often times with those little cheap tablets (I have had a few) the wifi is picky due to cheep part and software(the device).here are some common problems.Does it support the type of network your trying to connect to?is your network key too long? some device dont like itis you network name too long? is your router blocking access?(firewalls, filters,port forwarding, client limits)are you with in 10 feet of the router, wifi on tablet can be limiteddo other device connect to the internet via this methoddo you even have a wireless network of you own?make sure wifi is powered on?hard reset devicethe list of what the issue could be is infinite-Good Luck.
2answers
My laptop has limited internet access. I've called up my router provider and they said theres nothing wrong with the router as it works fine on all other laptops in my house. I have a sony vaio, I have...
Hello -
Depending upon where (in your home?) you use your Sony Vaio laptop (via WiFi?) you may need a WiFi booster or extender. Or, you may find that moving your WiFi router to another location in your home will improve your connection without diminishing the connections for other laptops used in your home.
Perhaps the information here will prove instructive:
https://www.repeaterstore.com/pages/wifi-booster-repeater-extender-differences
Note: If the router needs to be moved in your home, you will probably need a technician for your Internet provider to come to your home to relocate it and connect it properly.
Intermittent wi-fi
Most laptops you can just flip them over and open an access panel. Usually just 2 or 3 screws are all that stand in your way. Some laptops like 1000 Model HP's require you to remove the entire plastic panel on the bottom. You will recognize the wireless card inside by two distinct cables that attach to two corners of it. It is usually 1.5 x 1.5 inches big and will have one cable hooked to main and one to auxillary. These cards are available for purchase online if you google internal wireless cards notebook. There may be other types out there but i run into this one almost every time!
Dell Laptop WiFi Connection
Right click on the WiFi icon on the taskbar, select "view available wireless networks".
Then right click on change order of preferred networks
If the "Use windows to configure my wireless" is unticked, tick it
From the list below select the network you are trying to connect to and remove it and press OK
Then right click on the WiFi icon again and Vioew available networks and try to connect
2helpful
3answers
P1 wifi configuration
Hello laserxp,
for this time i want to tell you that i am not very familiar with the P1 wifi, however as my experience on the some wifi connection i only read the usermanual manual of the unit connecting to the internet.
please show me a picture and the model of the wifi so that i can figure out your problems.
melnavz
PS: pls donot rate me if the solution donot solve the issue.
2answers
Vaio laptop VGN-BX540B user
you should only need to enter the WEP key and get youre friend to remove your mac address. You may also need to refresh the ip address of your wireless card, so go to control panel>network connections>right click to properties>TCP/IP line>properties and ensure 'obtain ip address automatically' is ticked, then reastart your pc. Or you can also click Start>Run, then type ipconfig /flushdns, so as to renew your dns and ip address.
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
