Sewing a straight seam will be going well until the bottom thread suddenly becomes very loose and loopy. The top thread is completely fine. The only clue that this is happening is the spool "jumping" instead of unwinding silently and consistently. I suspect a bobbin problem...I rewound the bobbin, but it happened again resulting in more seams needing to be ripped out. Any ideas about what is happening with my bobbin?
Good morning,
A few steps to help you troubleshoot:
Please don't hesitate to respond if you need further help or clarification.
Remove the needleplate from your machine and inspect the opening for any rough spots... run your finger over the area to feel for any sharp bits. If you discover some rough spots, they can be smoothed using a fine emery cloth. Use this gently - don't want to distort needle opening, just smooth the roughness.
If no rough spots on needleplate, open the bobbin cover and turn the handwheel towards you until the hook (little pointy part of bobbin area) is towards the bottom of the machine. Run your finger over the point to feel for any rough spots. Again - a fine emery cloth can smooth this. Be VERY careful to not flatten the hook - just a little smoothing to get rid of rough bits. Too much can ruin the hook. If you're uncomfortable with this, don't hesitate to take to your Pfaff tech and point out the rough bits.
You can loosen the large setscrew on the side of the case to allow you to blow out whatever may be trapped.
Use a flashlight and look down into the top of the machine/takeup lever area. You may be able to see a bit of thread and remove it. If you can't see an offending bit, try "Flossing" your upper thread path by grasping the thread close to the spool and after it comes out of the needle. Run the thread back and forth through the thread path to see if you can dislodge anything
Happy sewing,
Kim & Linnette
Have tried putting the bobbin in facing every direction there is, and it still does the same thing. Was thinking it might have something to do with bobbin tension. Any ideas?
I can't seem to get the bobbin inserted the correct way because I too am getting irregular stitches and no stitches at all. I cannot find my manual, so I don't know the correct way to put the bobbin in. Can you please explain or illustrate it?
Same problem! Have already taken my Pfaff Hobby machine to a repair shop who did a good cleaning and said it was in good repair - Got it home and it began right away again *sigh*
My sewing machine is only 2 days old!!!!!!!!!!!!!! It was sewing perfectly, and out of no where it started looping, and i mean big loops, from the bobbin thread. I hadn't changed a thing. What could possibly be wrong.
The bottom thread from the bobbin comes out all messed up in the seam.
