U need to read the manual check out what is the default ip address of that router e.g if it is 192.168.0.1 then yours has to be 192.168.0.3 alsop check what is the username password to enter the router this should help u
The Linksys AE1000 Wireless USB Adapter
helps you connect your computer to a wireless network for quick Internet
access. Installing the Linksys AE1000 is fairly easy. Just follow the
steps below in setting up the Linksys AE1000 on your computer or laptop.
Minimum system requirements
- A computer with 1 GHz or faster processor.
- 512MB or more RAM.
- An available USB port.
NOTE: The Linksys AE1000 is supported for Windows 7, Vista SP1 and XP SP3 but NOT for Mac.
Step 1:
Insert the Setup CD into your CD-ROM drive.
Step 2:
Click Set up your Linksys Adapter. Proceed to Step 4.
If you do not see this, click Start on your computer and click Computer. Double-click on your CD-ROM drive. Continue to Step 3.
NOTE: For Windows XP, the file may be known as Setup.exe.
Step 3:
Read the License Agreement and click Next.
Step 4:
Insert the Wireless USB Adapter into a USB port on your computer or laptop.
Alternatively, you can also use the USB Extension Base
to connect the Wireless USB Adapter. Plug the Wireless USB Adapter into
the USB Extension Base and connect the Base to a USB port on your
computer or laptop.
Step 5:
If you have an Easy Setup key, select Yes, I have an Easy Setup Key and click Next. Proceed to Step 8.
Otherwise, select No, I don't have an Easy Setup Key and click Next. Proceed to Step 6.
NOTE: For more information on Easy Setup Key, click here.
Step 6:
Select your wireless network and click Next.
Step 7:
If prompted, enter the wireless password for your network. Proceed to Step 10.
Step 8:
Follow the on-screen instructions. Click Next once you have completed the on-screen instructions.
Step 9:
The installation is complete when you see the screen below. Click OK.
Step 10:
You are directed to the Cisco Connect screen. Click Close to exit.
Does your laptop have a wireless card suited for 802.11n? Most laptops that have been sold in the past years only support up to 802.11g and since 802.11n is a newer technology it most likely isn't supported by your laptop as of yet.
