20 Most Recent
Linksys WRT120N Router Questions & Answers
How do I get the security key setting?
I see that you are looking for the security Key settings, to be able to get your security key settings fir the Router you will need to get your Routers IP address.
Step 1. click the stat button on the lower left side of your Desktop screen, click all programs and look for Accessories, then click command promp this should show a black screen with a blinking cursor type in ipconfig then press enter this will show you information about your networks ip address, Look for Default gateway something like this 192.168.2.1 this varies on the router that you have.
Step 2. Enter the IP address on the address Bar of your browser then press enter this should show you the Routers settings page that is where you can see your routers settings for the security key.
to see your security key in windows you will need to check in device manager and click open Network and sharing center.
Upper right hand side you should see Manage wireless networks, click on Manager wireless networks it will show you a list of wireless Routers that you laptop has connected to, in the list look for the Router that you are connecting to and double left click on it it show you a window click on security this will show yout the settings for your windows security but the security will be encrypted as dots, the above instructions will show you how to get the security key from the router to be able to enter it in your windows settings and make the security key on the Router and your windows the same .
I hope that I have answered your question about getting your security Key :)
Ssid in vizio
SSID
log into router and check what it is and if it is broadcasted.
How do I find the network key / I need to add my table back to the map
In win 8.1 and 7 go to control panel and select the following in sequence.
1. Network and Sharing Center
2. Click on your Network Name (Shown in Blue)
3. When the WFI status window opens up select wireless properties.
4. Click on the security tab
5. When the panel opens up select "Show Characters" to display your network key.
Print or write out the key and save it in a safe place so you don't have to go through this again.
How to connect?
Hello Friend,
Connect you computer directly to the cable coming with the internet.
Type cmd in the start menu and when you reach the command box
Type config in the box
This will display the ipV4 address which should be the internet gateway.
if this is 192.168.1.1 then we have to change the router ip ti 192.168.1.2
please follow this link how to change rotuter ip adress
http://ui.linksys.com/files/WRT160N/v3/3.0.00/index.htm
In the mid of this page router ip should be done to 192.168.1.2
please contact me if this still does not work.
[email protected]
Lost cd download
Please go to this link and download the software.
http://support.linksys.com/en-us/support/routers/WRT120N
Driver download
The setup software can be downloaded from here: http://support.linksys.com/en-us/support/routers/WRT120N/download . The drivers will be included in the download.
