JVC GR-D250 Mini DV Digital Camcorder Logo
Siki Burd Posted on Jun 25, 2007
JVC camcorder with blurred images
One day I noticed that even though my camera was on automatic, the focus was off and the images were blurry. If I zoom in to a certain point it would be clear again but other than that it's just blurred. Did something go wrong with my settings or is my camera preparing for it's grave. Is there a way to troubleshoot this problem?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 29, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
783
Points
You could try using the focus button on the left side of your camera. Because I have the same camera and that happened to me before but if you just push the focus button a few times it show work.
Anonymous
Level 1:
Scholar:
  • Contributor 35 Answers
  • Posted on Jul 02, 2007
Anonymous
Contributor
Level 1:
Scholar:
Answers
35
Questions
0
Helped
12355
Points
72
It could be an issue with the dioptre adjustment: 1 Set the Power Switch to ?A? or ?M? while pressing down the Lock Button located on the switch. 2 Make sure the LCD monitor is closed and locked. Pull out the viewfinder fully and adjust it manually for best viewability. So slide the rubber eyecup toward you. 3 Turn the Dioptre Adjustment Control until the indications in the viewfinder are clearly focused. The control is a litttle knob on the sied of eye-piece. While looking through the viewfinder, turn the knob until it is focused. Hope this helps. NewMediaMan
I took some pics with celebrity they are blurred can i email them to you to get cleared up very dissapointed
Blurry pictures are not an easy photoshop fix. If the image is out of focus or has a motion blur it will be very tough. It really depends on what you are looking to use the image for as well. Sharpening can help but will be noticable if you try to make a large print.
Camera constantly takes blurred pictures
Appears that the auto focus mechanism is not working, This anomaly is most obvious in lower light situations when focusing is much more critical.
If the camera was new and two months old I would either return it for another one or have Nikon repair the lens assembly under the terms of its warranty.
Photos are blurred.
Blurred images are caused by several reasons: motion due to camera shake, use of slow shutter speeds and failure of the camera to focus correctly.
Slow shutter speeds
When light is low, wide apertures and slow shutter speeds will be selected automatically by the camera. Most people can't take blur-free, hand-held shots when the shutter speed is under 1/60th of a second.
Cameras that have optical Image Stabilization help but even IS has its limits. Increase room lighting, increase the ISO setting or use a tripod, or use a combination of all three.
Blurred images or misfocus
If an image is blurred due to camera shake, the blur will appear throughout the entire image. If parts of an image are in focus, and others are not, you've misfocused.
Sep 16, 2010 • Cameras
2helpful
2answers
Image in the viewfinder appears blurry
you have adjust diaptor wheel acoording to your eye setting. adjust your camera according to this sujetion you want get blurry picture.
you can get this diaptor wheel next to view finder.
I have an jvc gz-mg21e camcorder and the focus on it doesnt work
You have to change the iris unit on the optical block assy
12helpful
2answers
Nikon D40 will not focus
on the right side of the view finder there is a little bar. Make sure it is all the way down. If it is in the up position then it will make the viewfinder, shouldn't make the images blurry though. Also make sure it is in AF not MF (auto focus and manual focus).
Focus and or Zoom problem
double check that its still in auto focus, i went a whole day trying to figure out why my camera wouldnt focus, and i had auto focus off
Constant blurry photo's!
the solution to this is that your cameras are set to power save just put powersave on off temperarly while you snap a photo or the lighting in the room needs to be brighter with digital cameras even though theres a falsh it cant change the image contrast from dark to light so quickly so it just comes out blurry
Blurred monitor image
Hi I just experienced the same problem.Could NOT figure out what went wrong.The LCD screen image was blurred and as a result the pics I took were blurry:(
My husband then took over and simply cleaned off the front lens and POOF! It is back to good!Hope this helps!
2answers
Blurry Pictures
Check that you have not got Macro set accidently.
If lighting level are low and the camera is selectinging a slow speed - reset to Apeture Priority -setting 'A' and and be very gentle with the release - the slightest movement will blur an image on long exposure.
Try these thing and if still introuble come back with more detail
Top JVC Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
