SanDisk Sansa e250 MP3 Player Logo
Marisa Gertz Posted on Jun 22, 2007
WMP11: There are no files on this device.
Regardless of whether or not I am in rhapsody of playsforsure mode, when I connect my player to wmp11 it comes up with this message: "There are no files on this device. To begin, sync files to the device" when I try to view files I have already added to the player. I can add new files and playlists without a problem but I cannot view the files within wmp afterwards, only using explorer. Why?!
  • seegmiller_5 Feb 09, 2009
    I don't change the USB mode and still have the same problem. So that is not a solution. Any other ideas?
  • seegmiller_5 May 11, 2010
    The USB mode has nothing to do with this problem. I haven't changed the mode and I still get the same error. I have also changed the USB mode and got the same message. You only see the files you transfered the paticular mode you transfered them in, right? If you are always in music mode then why would I get the error? So please offer other assistance.
Anonymous
Level 1:
  • Contributor 80 Answers
  • Posted on Jul 21, 2007
Anonymous
Contributor
Level 1:
Answers
80
Questions
26
Helped
24793
Points
78
The player was not desing to work with wpm.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 09, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
472
Points
This player IS designed to work with WMP. On your Sansa, go to Settings > USB Mode and switch to MTP. Now you should be able to see all of your files on your player.
2helpful
2answers
I can't find a download site for drivers.
The player should be detected in Windows Media Player 11 automatically. If not, look in WMP11 under Sync in the page top if you can manage to get the device recognized manually. An update of the operating system and WMP11 maybe required to get the function to work.
After download and installation, run Coby Media Manager: select Tools > Device Manager...: select MP-705 from the list: click Add : click OK to have the MP-705 as your operating device.
How to operate sansa and creating data base
Sansa support for e200 series:
http://www.sansa.com/support/sansa_e200/faqs
user manual e200
For making videos appropriate for your player use:
sansa media converter
When a total reinstall for the player is required perform:
sansa firmware updater
Remember: running a firmware update will erase all data on the player !
For transferring files from the computer towards the player you can use
Windows Media Player 11. A short guide in how to make transfers:
1. Have WMP11 always on top for "drag and drop" usage
Right click in the head of the WMP11 page:
in Tools > Options... > Player : select "Keep the player on top ..."
Restore Down the size of the WMP11 screen and adjust the size on the
edge(s) as you require for your screen.
2. in [Library] mode: under Playlists "Create Playlist" e.g. "My Playlist"
and Enter: "My Playlist" is added on the right screen side.
3. Open your data maps and ad files by drag and drop method
onto the right saying "Drag items here"
4. when ready adding files in [Library] mode: "Save Playlist"
5. in [Sync] mode drag e.g. "My Playlist" under the connected device
and "Start Sync": wait until al files have synchronized: a message
will show up when you can disconnect the player.
Transfer media
A guide in how to transfer media for the RCA Opal M4001 see this manual in pdf format: manual for RCA Opal M4001
For more help on for this device see the support site:
support for RCA Opal M4001
When using Windows Media Player 11, a short description how to deal
with putting media on the device:
Note; convert video with the RCA video converter on the computer
before transferring it onto the player.
A download can be acquired with the next link:
download RCA video converter
1. download the execute file
2. install the converter by clicking on the execute file:
" rcasmvconverter_v1.6.2.0.exe "
How can i get videos on my mp4
There's an online manual for COBY mp-c7095 in pdf format:
http://www.cobyusa.com/files/manuals/MPC7095_MN.pdf
1. Use the video conversion software from the CD for adjusting
video to correct size before transferring to the player.
2. Check the system requirements for video conversion on page 34.
The conversion software in zip format can be downloaded with this link:
http://www.cobyusa.com/files/software/MTVVideoConverter_Ver1.12.11.zip
Once video is converted u could use Windows Media Player 11 for
transfers. A short guide on WMP11 for putting files onto the device:
Lookins for software
HDD14xx GoGear:
manual
software and drivers
The manual shows how to make lists and transfers with your player.
A short guide on how to use Windows Media Player 11:
3. Open your music maps and ad songs by drag and drop method
4. when ready adding songs in [Library] mode: "Save Playlist"
14helpful
2answers
Playlist on go gear vibe
Using Windows Media Player 11 ?
Right click in the head of the WMP11 page: in Tools > Options... > Player : select "Keep the player on top ..."
RE:WINDOWS MEDIA PLAYER 11 IN VISTA
Does your player show up as being connected in WMP11
Sync mode ? If not, a firmware installation for the player is needed.
If yes, did you perform doing next actions ?
How to download songs
1. Are you using Windows Media Player 11 ?
2. Can you see the Sansa e250 connected in the sync mode ?
If no: install and update WMP11
If yes:
3. Make "new playlist" in the <Library> or <Sync> mode
of WMP 11; screen left side.
3.1 Save "new playlist" in WMP11; screen right side.
4. Put in <Sync> mode your playlist under the player: The player
should be connected showing in WMP11. Start synchronizing.
Leave the player connected until <Sync> is ready.
Support for Sansa e250:
http://www.sansa.com/sites/default/files/downloads/e200_userguide_en.pdf
Sansa Clip 2GB...WMP11 will recognize, but will not list in device pane in Sync mode...
Hah, figured it out! Had to roll back my version of WMP, which can simply be done by (in XP) going to Start > Control Panel > Add Remove Programs, and then click on WMP11 in the program list. Click remove, and it will ask if you want to roll back to the previous version of Windows. Click yes, and it will roll it back to the previous version of WMP11. Now, assuming you have an active internet connection, after you restart your computer, it will ask if you want to update your WMP. Click yes, and it will re-install the version you started out with, replacing drivers, .dlls, and anything you were missing before hand. Long story short, the solution was patching the holes in the program. I can now plug my Sansa Clip 2GB into the USB port, and WMP will recognize it right away (I can almost hear a small voice from inside my computer saying "would you like tea with that, mr. guy?" hah). I also found out you can have more than one media player connected at the same time! How cool is that? Great if you're trying to set up multiple players with the same playlists (promotional type stuff, business type stuff, etc.).
2answers
Doesnt detect in MTP mode
I had this type of problem, excluding Rhapsody, but when the computer was updated, everything fixed. Sorry I couldn't help more. I think we updated Windows Media Player, but I think ours was 10, not 11. Try running auto update.
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
