HP Pavilion dv6000z Notebook Logo
Posted on Jan 16, 2009
How to hook up a hp pavilion laptop to a hdtv
I have a vizio 37" hdtv, and i have a hp pavilion dv7 laptop with a blue ray player. i have tried to hook up my laptop with my tv by using a hdmi cable. at first it worked but now nothing shows up. i have read that i need a dvi to hdmi cable. i dont have a dvi input on my tv or laptop. i have a hdmi hook up on my laptop and tv. plus i have a s-video on both. is there a way to use the hdmi cable, and why is it that i hook it up and nothing shows up on my tv. any help would be great?
  • Anonymous Apr 10, 2009
    want to hook pavillion dv97oo to television. Thanks
  • Anonymous Mar 30, 2014
    I am using an HDMI to DVI cable to my monitor and it will not show a display
Anonymous
Level 1:
  • Contributor 36 Answers
  • Posted on Jan 16, 2009
Anonymous
Contributor
Level 1:
Answers
36
Questions
0
Helped
22040
Points
78
If it worked fine at some point then it should work fine now... i use hdmi to hdmi from my laptop to tv all the time dvi would only cause quality loss.
the first thing i would try would be to change your resolution on your laptop to a couple different settings. a lot of times, if its not set to one thats compatible with your tv, you won't see anything.
if that doesn't work, go to personalization and open the tab that says "connect an external display" and toy around with it. but yeah it doesn't sound like you have any hardware problems there.
hope this helps
Where I can buy HP battery for laptop Model Pavilion DMI
try contacting nearest HP laptop dealer in area for possible replacement batteries or the store may provide you with contact information for directly ordering from HP company/supplier.
Vizio 37" tv. sound loud enough on satellite and antenna. when hooked to dvd or blue ray, can hardly hear it even at maximum sound
I have a similar problem with my new 37 inch vizio. Watching on cable and the sounds gets lower and lower until i can hardly hear it. Must switch channels back and forth to restore the sound level of a particular channel. Does anybody have a solution ?
MY HP PAVILION DV7-1267D WONT PLAY BLUE RAY
How do I enable my wireless capabilities?
Is the price of HP Pavilion dv7 battery for hp
That's expensive.
Try http://www.bestezonlinestore.com/home.php?cat=10002063
Quite cheap batteries.
I can play dvd and cds in my ble ray but i cant play blueray cd its a hp pavillion notebook
you're notebook is not blue-ray compatible, most likely. You're laptop, dv2000t PC, was made when blue-ray was not manufactured yet. OR, maybe you can try a blue-ray running player software; try searching for it on google.
2helpful
Printer port for my new hp pavilion dv7?
You should be able to use a parallel to usb converter heres one in the link. There hard to find most are usb to parallel but this should work.
http://www.usbtech.com.au/product.php?productID=GW-K200
No audio output hooked up to my Vizio 37" LCD
You need to select digital out in the menu of the dvd player..
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
