I tried to install the PMB software on my Windows XP laptop so i can download my pictures and videos; but the message that keeps coming up is an installation error and in the Control panel Device Manager, it says "Reinstall the drivers for this device. (Code 18)". I have re-installed and nothing changes so I am wondering what it is that is the problem.
SOURCE: My Sony DVD RW stopped working.. with error messages.
Hey its really worked Thanks Nitesh Oza
SOURCE: Unable to Install Drivers
Try to re-install your motherboards chipset (inf) driver.after that try to install your mp3 player.
Thanks
SOURCE: Sony Handycam DCR-HC42 Mini DV not recognized by Windows 7
win vista and win 7doesn't support usb streaming. the usb driver for this model would not be compatible with your computer's OS. although, you were able to download PMB still this wouldn't work, it's basically an alternative software that you can use with the newer OS. still the device driver would not be installed. and you would get a message that "ilink connection is not detected". the reason you get that is bec the camcorder and the software is intended for use with the dv (ilink or ieee1394) connection. so if your computer has an ieee1394 card and you have a compatible ilink cable,then your good to go,it should be a plug-and-play connection (no drivers required). all you need then would be a video capturing software (like win moviemaker) to transfer videos from tape to PC. hope this helps. thanks :)
