Dear sir. i have lenovo ideapad z570... for few days because of software issue...booting issue..i gave my laptop to the service centre.. they help me well and clear the problem..... but sir they change the SATA controller:ahci to compability...i dont know wht is compability mens...and is good for my lenovo z570 or ahci..and sir after installing os(windows 7ultimate).....every thing works fine ....but when i install driver of AHCI....IT SAYS ["""""the computer does not meet the minimum requirement for installing the software"""""""" ]...... SIR.pl give me step by step details...and expalin this compability and ahci..... and i want to install again in ...ahci mode pl help....as soon as possible thank u!!!!! and sir should it possible to upgrade windows 8...in lenovo z570 ideapad..through windows 7ultimate
This is a setting in you BIOS. Try changing to AUTO under the SATA drive settings by pressing F key during boot. It will be noted on screen during startup.
I would stay away from a OS upgrade till your are certain all hardware and software is compatible. It is a lot of work if it does not work properly.
can u pl explain me...step by step sir pl.....because i already install the windows 7 ultimate.....would u like to install me again and do this step sir..or can i go to the SATA controller mode and change the compability to achi.MODE..and then install again windows...should this help full to me..AND WORKS all properly ..
Green means you have a full battery charge.
So probably it seems your battery is out of juice. Keep it on charges & it should be fine.
If there is nothing changed, you may need to exchange the laptop charger.
Lenovo IdeaPad Z570 AC Adapter
Hope this helps.
