There appears to be power going to the unit it also sounds like the hard drive is working I did notice the green light on the power button does not flash which I believe it did when the computer was working properly
SOURCE: The power button no longer works. IS the
i think your power supply has blown, take it to a computer store and ask them to replace the power supply then your problems should be over but you could just ask them to transfer computer box and that should also fix your problem because most boxes have a power supply in them. a small test you can do before that is get a switch open the pc and connect it to the mother board (without soldering it) if it turns on it is the switch then you buy a box if it doesn't make sure you dont use a toggle switch if you use a small hold switch and it wont turn on get a new box.
SOURCE: when turned on the computer power light comes on
Sounds like the memory is faulty. If there theres more than 1 memory module just try one at a time until you find the faulty 1. If only 1 in there replace it the speed of memory should be written on the old one. Cheers from Scott pls dont forget to vote
SOURCE: My emachine C3070 won't run!
Welcome to Fixya. I would like to verify some importand details about the issue so that we can determine the cause of the problem. When you turn on the computer the power indicator, cooling fans and hard drive works but there is no display on the monitor is that what you meant? If this is happening on the computer it is called no boot, no display or no post. POST is the power on self test that you will see incase you turn on the computer. In your case since the monitor is working on the other computer it means that that is ot the problem. If no display happens on a computer an you are using the onboard display the problem is the MOTHERBOARD. Please stop tuning on the computer because this might case other problem on the other device on the computer like the hard drive, memory and the processor. It would be better to chage the motherboard of the computer or check the warranty of it then bring it to acer or emachine service center for them to replace it. CMos battery will not fox this issue. Start up disk won't either because this is a hardware issue.
If you have questions please let me know. Thanks for using Fixya.
SOURCE: I have the Emachines W3115, Problem #1 It has been
sounds like a bad power supply... get one from newegg.com they are easy to replace, it will only plug in to the place it is supposed to.... check wattage out put and get same or higher
SOURCE: no signal to moniter emachine t5048
DID YOU TRY A DIFFERENT MONITOR TO SEE IF THATS IT OR IT THE COMPUTER. SETTING COUSE THAT PROBLEM TO. THIS MAY HELP.
