20 Most Recent
eMachines EL1852G-52W Questions & Answers
What parts are needed to set up wifi?
That machine does not appear to have any PCI slots, or built-in WI-Fi. You may be able to get a USB 2 Wi-Fi adapter. Just make sure the one you get works with your Operating System. Also, you will have to have a Wi-Fi router to connect to your Internet Service Provider.
7/18/2014 7:20:24 PM •
eMachines...
Answered
on Jul 18, 2014
Cd stuck in computer
There should be a small hole on the frond of the CD Drive. Unbend a paperclip and insert it into the hole and it should release the CD.
3/16/2014 2:42:41 AM •
eMachines...
Answered
on Mar 16, 2014
I had a virus on my computer and I cleaned it. Now I can't get the internet on it. Do I need to download it , if so where can I go to download it?
Which operating system ?
You will have to open up your network connections.
Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled.
Click start control panel administration tools computer management device manager look for network adapters + expand Ethernet driver if you see a yellow Question/ Exclamation mark ? ! or a Red X you will need to update/reinstall the driver for the device
You only need check the following if you cant install the driver
Make sure you Ethernet/internet is enabled in bios.
Restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals
look for SiS On Chip Pci Device press Enter make sure its enabled
then recheck the driveri t should be there
k the driver it should be there
make sure its enabledPci device arrows key scroll to nstalled
if you computer came with a motherboard disk the driver could be on it
or this disk provided by your ISP provider Internet Service Provider
or you might have to download one
http://download.cnet.com/wireless-atheros-ar5b91-7/3000-2112_4-202570.html
http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000-2112_4-91313.html
if these packages are not the right
http://download.cnet.com/2000-20_4.html
On the home page you should see a search tab just type in what you are looking for
tick in the box for windows software or all software box
IE: Motherboard name Wireless or Ethernet driver
you might have to try a few times to get it right
2/25/2014 6:11:05 AM •
eMachines...
Answered
on Feb 25, 2014
I counted 13 quick beeps at startup on an emachines E520. what dose that mean ? how do i fix it please ?
Thirteen quick beeps at startup on an eMachines E520 usually indicate a problem with the laptop's RAM (Random Access Memory). This could mean that the RAM is not properly seated in its slot, or it could be a sign of a faulty RAM module.
Here are some troubleshooting steps you can try to resolve this issue:
Turn off the laptop and disconnect it from the power source.
Remove the battery from the laptop.
Locate the RAM compartment on the bottom of the laptop.
Check to make sure that the RAM module is seated properly in its slot. You may need to remove and reinsert the RAM module to ensure a proper connection.
Replace the battery and turn on the laptop.
If the problem persists, try removing the RAM module and testing it in a different laptop or using a different RAM module in the eMachines E520 to determine if the problem is with the RAM module itself or with the laptop's RAM slot.
If none of these steps solve the problem, it may be necessary to contact a computer technician for further assistance..
3/22/2023 9:07:20 PM •
eMachines...
Answered
on Mar 22, 2023
How to factory reset a Emachines Etower 633id it boots up but says operating system not found it has Microsoft Windows ME Millennium Edititon (from Windows 2000 Professional)
- Boot the computer to the boot menu: To do this, restart the computer and press the appropriate key when prompted to enter the boot menu. On most eMachines computers, this is the "F12" key.
- Select the CD/DVD drive as the boot device: Use the arrow keys to select the CD/DVD drive and press the "Enter" key to boot from it.
- Insert the Windows ME boot disk: Insert the boot disk into the CD/DVD drive and restart the computer.
- Choose the "Start Computer with CD-ROM support" option: When prompted, choose the "Start Computer with CD-ROM support" option.
- Run the Windows ME setup program: The setup program should start automatically. Follow the on-screen instructions to install Windows ME.
- Format the hard drive: During the setup process, you will be prompted to format the hard drive. Choose the "Full" format option to erase all existing data and perform a complete factory reset.
- Install Windows ME: Continue to follow the on-screen instructions to complete the installation of Windows ME.
After the installation is complete, the computer should be in a factory reset state and you can begin setting it up as a new system.
Please note that resetting your computer to the factory settings will erase all personal data and installed programs, so be sure to back up any important data before proceeding with the reset.
2/13/2023 2:51:11 AM •
eMachines...
Answered
on Feb 13, 2023
My local disk E is missing.
device manager
1 of 10000 model ODD optical disk drives made,
each drive made has LIMITS some only do CD ROMS
BD is blue ray , FIY
if missing or maked with red or yellow errors or shows up as unknown that all means DRIVER IS BAD , wrong or missiong
NO PC Told so can not tell you how to fix that, lacking such a key fact . (but is at your oem makers PC support page under DRIVERS)
6/21/2022 8:52:19 PM •
eMachines...
Answered
on Jun 21, 2022
