20 Most Recent Sharp XR-10S DLP Projector Questions & Answers
its due to dust on color wheel clean the sensor and wheel. Problem will solve
Sharp XR-10S DLP... | Answered on Nov 03, 2013
It sounds like your input signal is in 4:3 and the projector is in 16:9.
You need to adjust the "Resize" mode.
On your remote, press the "Resize" button (bottom-right of the remote, looks like a screen with two arrows pointing left and right [< >]) until it is in "Normal" mode. If that does not work, try setting it to "Border".
Sharp XR-10S DLP... | Answered on Mar 13, 2011
look at your lamp carefully to see if you see bubbles in the mirror or anything like that. if so then your power supply/ballast is bad.
Sharp XR-10S DLP... | Answered on May 24, 2010
It seems front fan or color wheel damage
Sharp XR-10S DLP... | Answered on Mar 03, 2010
It is mother board problem.Reverse side of the board 5 pin ic not giving 12 volt.pin no. 1 input 12volt and pin no.3 12 volt out.it might be damage
may be either the colorwheel or the ballast. if you hear the colorwheel spin up (high-pitched whir), replace the ballast. if you don't hear it, replace the colorwheel.
Sharp XR-10S DLP... | Answered on Feb 28, 2010
I think it's capacitor issue on the power supply board. open it, look for power supply board and fine bloated capacitor and replace it.
Sharp XR-10S DLP... | Answered on Feb 15, 2010
either press the source button on the top panel or select the input through the menu.
Sharp XR-10S DLP... | Answered on Dec 29, 2009
try av solutions in ny. they're a sharp service center. www.avsolutionsny.com
Sharp XR-10S DLP... | Answered on Dec 21, 2009
if you did not hit the power button it would not of broken it
Sharp XR-10S DLP... | Answered on Oct 03, 2009
Problem with your fuser unit. Bad heater element or bad rollers or thermistor
Sharp Office... | Answered on Dec 04, 2019
It is the toner light if it is a triangle of red dots
Is it the toner light which is a triangle of dots or the waste toner light which has a line under it ?
Here is a link: http://siica.sharpusa.com/product-downloads
did you clear the require counter and run the required test before (counters) and test after ward????
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Sharp Office... | Answered on Dec 02, 2019
Sharp XR-10S DLP Projector Logo
Popular Tags
19 questions posted
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Office Equipment & Supplies
Most Popular Question
color projected darker tone
  • Office Equipment & Supplies
