Try these links and see if they will help you
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&frm=1&source=web&cd=1&cad=rja&ved=0CC0QFjAA&url=http%3A%2F%2Fwww.raichert.com%2Fadobe%2FLU562%2520LU563.pdf&ei=YUWlUKG7PI_SiAKK8YCoAg&usg=AFQjCNFCrsdOZ6gBJOfeMPpFp2Wjiqu8ZQ
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&frm=1&source=web&cd=3&cad=rja&ved=0CDgQFjAC&url=http%3A%2F%2Fwww.sewingmachinemanuals.com%2Fjuki-lu-562&ei=YUWlUKG7PI_SiAKK8YCoAg&usg=AFQjCNFGkqSwJ6oI9jdf8oZlL5Ffd15dVQ
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&frm=1&source=web&cd=4&cad=rja&ved=0CD0QFjAD&url=http%3A%2F%2Fatlaslevy.3dcartstores.com%2FJuki-LU562-LU563-user-manual_p_2799.html&ei=YUWlUKG7PI_SiAKK8YCoAg&usg=AFQjCNHl_jg-TbP_PR6PUi68zU_209sG1Q
SOURCE: thread keeps breaking on sewing machine
Probably just the needle. Try turning it 180 degrees
SOURCE: I need a manual for a JUKI LU 563
JUST check at google ,com manuals
and then write you model# or you can go directly to your manufactury on line or if you heve costumer service # call them
SOURCE: I have a Juki Lu-562. The safety clutch counter
click this link directly .http://www.raichert.com/adobe/LU562%20LU563.pdf ------ its mentioned on page number 12 of the link.ablout the clutch spring adjustment. --------- check out.keep updated.thanks.
SOURCE: Need instructions for threading Juki MO 3314
Open the font of the serger and the instructions will be printed on the serger or on the door.
Raise the presser foot and set the tensions to zero when threading.
Turn the hand wheel so the upper looper (curved one) is at it's highest point and thread it first, and then the lower looper.
With some sergers you must thread in a certain sequence. This should be indicated in the instructions on the serger.
Set the tensions back to normal ( 4 - 6), lower the presser foot and run a length of stitching to see if the threads are knitted together as they should before you start serging your project.
