If the set has a input or source button on the outside or side it can be got at and removed (not the plastic button but the switch under it) they do fail in this way and with it removed and the issue gone you can use the remote instead.
wow thanks for the fast response i will try doing that thank you so much this really helps im so broke right now . if this doesnt work what else might iit be nd thanks againwow thanks for the fast response i will try doing that thank you so much this really helps im so broke right now . if this doesnt work what else might iit be nd thanks again
You can't post conmments that contain an email address.
You can leave the input from the Roku hooked up, hook the antenna to the round connector that says antenna or cable on the tv then select cable or antenna as the input on the TV and select auto scan and let it scan for live chanels and store them...you can switch back and forth between the HDMI input for the Roku and the cable/antenna using the input button on the TV, you won't need to unhook or re hook anything to go from one source to the other.
? 2:34
https://www.youtube.com/watch?v=ZtaUPX1tHP0
May 26, 2015 - Uploaded by ShopJimmy.com
Basic troubleshooting and replacement tips for HDMI inputs that are not ... video or audio from your HDMI port, you can take the source video ...
CNETJun 14, 2014 - Sunday my husband hooked up an RCA ANT571 antenna with great results. ... The Roku first showed no signal on the TV. I tried hooking the Roku up to other HDMI ports, i changed the hdmi cables, .... Sound comes through, but not picture. ..... Video; All Video · Apple Byte · Carfection · CNET Top 5 · CNET ...
Oct 11, 2012 - The video is excellent, but there is no sound coming out of my TVspeakers. ..... I also tried inputs besides the "HDMI 1" input and the other RCA ...
First you'll need to make sure your TV is on the correct input. By the way, it's likely your TV is ok, unless the input you're using is defective. If you have an external antenna for over the air reception the TV must be on the antenna input and set to Air or Antenna, not cable. If you have basic cable the input must be set to cable. If you have a box for cable or satellite you can use antenna, composite, component or HDMI input. HDMI or component will give you the best picture. At this point just make sure the TV is set to the same input the box is connected to. If you still see the no signal then the Main board is bad.
There is a button on your remote control to change the input method. You press the button to change it. Examples of input choices are AUX, Antenna 1 & 2, cable, tv, hdmi. Keep pressing the input button until you see a picture or find the HDMI choice. That should solve your problem.
You have to go into the input menu and select HDMI as you are on the antenna source at the moment, Look for "input" or "source" button on your remote control and go to HDMI and press "select" "o.k" or "enter" button. Best of luck.
did you switch the TV's incoming signal to digital antenna? For the cable box it was probably set to cable antenna or analog inputs, not all TV's have automatic switching for antenna feeds. My Mitsubishi has 1 digital and 1 analog antenna input and the cable box will only work through the antenna input if it's the analog antenna input and it's tuned to channel 3 or 4, -(or through a seprate HDMI, PROSCAN, SVCR,or a yellow RCA plug input)- and when the analog antenna input is selected the TV will tune all analog cable channels that the cable service offers if a box is not used. likewise the TV will not tune any channels at all if it's set to digital antenna inputs. It will tune all local channels only when set to digital antenna inputs.
I am having a similar problem with the inputs. I have a cable box plugged in to cable antenna, DVD to video 6 using HDMI, Mac computer plugged in to video 7 - using HDMI (TV does not recognize this) and then Nintendo Wii hooked up to Video 1. My problem is that Sony only realizes 2 additional components like the video 1 (wii) and DVD on video 6, it does not play the other components. I have to niw manually switch the cables to have them work...
THE BEST INPUT ON YOUR SET IS THE HDMI INPUT.2ND THE COMPOSITE INPUT. 3RD THE COMPONENT INPUT. AND 4TH THE ANTENNA INPUT. MOST DISH BOXES HAVE AT LEAST THE COMPONENT OUTPUT. YELLOW IS THE VIDEO AND RED AND WHITE FOR AUDIO. USE RCA CABLES TO GO FROM BOX TO LCD SET. ON THE DISH BOX YOU CAN GO FROM ANTENNA OUT TO THE CABLE OR ANTENNA IN ON THE LCD. SWITCH TV TO CHANNEL 3. AND TURN YOUR DISH BOX ON.
