20 Most Recent
Protron PLTV-4250 42 in. LCD Television Questions & Answers
Power automatically turns off and picture is all pink
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
2/11/2018 10:43:01 AM •
Protron...
Answered
on Feb 11, 2018
Why did it work before installation, now flashes numerous different colors?
Before installing replacement parts???
I can assume that the t-con board or the video board had terminal connectors or ribbon connectors. What is often overlooked is a misaligned connector or worse, a broken or bent pin. Try examining these connection points. You may have to use a magnifying glass. A defective screen usually goes black or produces broken images and/or color points.
I hope this helps.
5/31/2015 5:49:55 PM •
Protron...
Answered
on May 31, 2015
How do I hook an antenna to my tv
Hi Dwayne,
The Proton has an NTSC analog tuner and also an ATSC digital tuner. Have you tried switching or changing the SOURCE inputs?
You may also have to use the scan button to have the tuner "find" the channels for you once you determine that you have selected the correct source for the antenna.
See page 9 of the manual.
http://www.manualslib.com/manual/323457/Protron-Pltv-4250.html?page=17#manual
1/18/2015 10:09:25 PM •
Protron...
Answered
on Jan 18, 2015
