20 Most Recent
HP 2509m 25 in. TV Questions & Answers
How do you watch tv on This monitor?
The hp2509m is just a monitor it doesn't have the ability by itself to watch TV.whoever told you that it had this feature was misinforming you.
However any monitor connected to a computer can display video streamed from a TV station over the internet with the right software. Try a search forfor a TV aggregator on google to find one to fit your needs.
Monitor wont recognize my remote control
Confirm first the remote is actually working---it can be tested with a tester made for this and some digital cameras in a very dim room will react when the remote is pointed at them by flashing on the LCD display screen when buttons are pressed.If remote is good about all that is left is a bad receiver in the set---a very very few sets do have a lockout feature for the remote but it is rare. typical remote receiver, some do not have the metal frame.
Where is the Logik LPV 09 HP reset button
The location of the reset button on the Logik LPV 09 HP would likely be in the owner's manual or on the company's website. It is also possible that the device does not have a physical reset button and can be reset through software or by unplugging the device for a certain amount of time. If you cannot find the information in the manual or on the website, you should contact the manufacturer for assistance. if i was able to help my cashapp $ralphpapi thank you have a blessing day
I try to start a HP iq775. When I press the power button I heard one short beep and I see a red light red and then blue, and turn off inmediately. The PC won't start. The power supply works fine. Help
All HP iq77x all-in-one PCs suffer from the same problem of a faulty motherboard. This is primarily a soldering issue on the graphics chip,which develops cracks in the solder balls. The PCs contained a separate graphics card, which goes faulty first. This can be removed and the display connector can be moved on the motherboard to use the on-board graphics. This will eventually show the same issue. A short term fix was to heat the graphics chip with a hot air gun or other means (plenty of suggestions can be found on-line) which sometimes works for a few weeks at most. The only 'permanent' fix is to have the chip professionally removed and re-soldered; an expensive option.
If you are lucky, your PC is still wired to use the add-on graphics card, in which case you might be able to remove this and rewire for the motherboard graphics.
I have a HP MD5820N tv and it started making a loud humming noise and the colour went all dark and flickering and now will not turn on, the red lights flashes twice under the light bulb and thermometer pictures
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. See the site by a desktop. Mobile view has no search box. If you are viewing it by your mobile, see it in webview./
White vertical bars on HP PL4260N Plasma TV. What recommendations for repairs and or boards affected in TV set
If those bars are vertical are going up and down and not horizontal that means the lower circuit board that connect to the plasma panel are bad most likely this is an LG TV but this is not something that can be fixed you can take it apart while at least an hour after it's unplugged before you can touch ID cards along the long circuit board see if there's any connection connection connection that you can disconnect and reconnect and very carefully clean up possibly this could be the problem but usually when you have that type of line which is a vertical line you have a bad panel and that's not good and I'm betting this is an LG TV
