Hi
When your red light is on with the handest down presss the message key. this will tell you where the message has come from. I expect you will see that an internal extension has dialled you by mistake. It is a message waiting function on the system for user to call back on. Nothing to worry about. To clear the light you have 2 options either press the clear button on the display for each message or dial *700(then your extension number)
Speak Soon
Phil
SOURCE: we have had a panasonic
We have this model also, and have exerienced similar problems. Try disconnecting all of the phone lines for that ph number, for a minimum of 30 seconds. Reconnect and the line should be functioning again. It always works for me.
SOURCE: Message Lamp does not light
This will be a two step answer. Walk to any other extension and dial *701 plus the extension that doesn't work. If it lights the message waiting lamp (of course it will), then please look for your voice mail system cabinet. It may be black, with a dark blue cover the same as the TDA phone system. Part numbers would be TVA-50 or TVA-100.
If all of the above is true, you need to do some notification programming in the voice mail system. Do you have the programming software if it's a TVA?
Carl
SOURCE: Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Testimonial: "This responder did nothing but repeat my initial post and yet gets credit for a solution?"
SOURCE: I have an issue with a panasonic model KX-T7630
Press MESSAGE and look at the display. It will tell you where the message is from and one of the soft keys will say CLEAR.
Carl
SOURCE: MESSAGE LIGHT STAYS LIT
Press the MESSAGE button and look at the display.
It will tell you where the message is from and let you erase it via the softkeys.
Carl
Testimonial: "WORKED GREAT THANKS "
