1. Turn on your bluetooth and make sure that it's not connected to other devices.
2. Put the Bluetooth in seeking mode(searching for devices)
3. Go to your iphone and go to settings, General, Bluetooth and turn it on.
4. Once your phone picks up the Bluetooth click it. Then it will then ask you for a 4 digit pass code. Standard ones are 1234 or 0000.
5. If that still doesn't work try turning off your Bluetooth and then turn it back on holding the power button. This will allow it to restart and start again. (this is what I did for mine) then repeat the process again.
Hope this helps.
SOURCE: How to pair a Motorola D200 to a phone??
The D200 is intended to stream music or audio from the PC to Bluetooth devices such has mono headsets or stereo headphones. It does not interact with a cellular phone.
You can also do VoIP calls with D200 (plugged into a PC using Skype or a similar program) and a Bluetooth headset. I use this so I am not tied to my computer when I am using Skype for calls.
SOURCE: what is bluetooth about it? can it be paired with
If your phone has blue tooth, then yes it can be paired to a blue tooth headset.
SOURCE: Convert dvd to iphone 4s? help plz..
Here is a tutorials for this: http://www.dvdconvertersoft.com/how-to-convert-dvd-to-iphone-4s/
