I have a top with a tie wrapped around the agitator. How do I get it unstuck?
SOURCE: pants tie stuck around agitator
If yours is real old
pop the small cap off and remove the screw
If it is newer you yank the agitator off there by grabbing the neck
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Piece of cloth wrapped around and under the shaft
I don't know if this washer is very similar to a model wpre6150k2wt. My girlfriend had this very problem happen to her with her washer that is this model. The solution was very easy, I just unscrewed and took out the fabric softener dispenser. Doing this gave me access to a bolt that attaches the agitator to the gear that turns it. I then just unscrewed the bolt and removed the agitator. I hope this helps. Again if your washer is similar to ours it should.
