20 Most Recent
Kenmore 24902 Top Load Washer Questions & Answers
Hot water only filling my Kenmore series 80 . I replaced my valve and still the same problem.
Swap the wiring to the valves, that will tell you if it's the valve or control board. You should/could also measure the voltage across the valve when it's supposed to be operating. If it's line voltage the valve is faulty, if not it's likely the control board. If the one you put in is new and tests ok then it's the control board feeding the valve, probably a thyristor or similar switching device faulty. If you aren't qualified BE CAREFUL THERE ARE HIGH VOLTAGES IN THAT AREA
Washer has filled but will not start
try to manual move to the wash option if it washes then stops after was it maybe the logic board ( brains unit ) not going to the next option. if it is a mechanical dial that rotates it will need replacing.
WONT AGITATE OR SPIN
check the belt that spins the tub, you will find it at the bottom of the machine, check if its intact.
plz do not forget to vote if i solved your problem
