The contac in the wall is correct but on the micro dont have aniting
Check to see if the power from the wall socket is there. Plug in a lamp or somthing. If it works, then the microwave burned out an internal fuse, or curcuit board.
Testimonial: "tanks "
the socket is working and check the fuse but were is the curcuit boared?
if the socket is working, the breaker is fine. The breaker is at the main house panel and cuts the power to the socket. This is an internal appliance issue. I do not suggest opening it up to check for a fuse unless you are capable of basic electronic repair.
locate the microwave's power supply cord.Remove the power supply cord from the wall outlet.Wait one to two minutes.Re-insert the power supply cord into the wall outlet. The microwave is now reset.
