The bin won't fill up, it melts too fast. The curtain has about a 2 inch tear on one side and water was running down instead of into the right place, could this melt the ice?
SOURCE: Brand new Scotsman DCE33 ice maker melts ice
Check that the condenser is clean, the plastic sheet is hanging over the opening and trhat both spray nozzles are in place.
SOURCE: my cme 256a8 model scotsman ice melts to fast
There are a couple of things to check. The machine must be level. You can remove the front cover and the plastic sheet that covers the plate where the ice is made. Check to see that the water is flowing from the manifold at the top of the plate. You may have to pop the hose off the end of that manifold to clean the water holes out. It must flow evenly over the plate. Probably the most common problem is the radiator coil there the fan draws air through is clogged up so that it can't dissapate heat properly. You should be able to feel a lot of hot air moving through the coils. The fan cycles on and off periodically to maintain a certain pressure in the freon. That is normal. Clean the fan coils and level the machine.
