Soyo MT-SYTPT3718AB 37 in. LCD Television Logo
Black fog came upon on the picture screen and turn completely off. Tried unplugging from the tv and electrical outlet no luck....please HELP!!!
Viore led42vf80 black screen
If you have no sound and no video but you have power to the tv then you have to look at the source. Source being your Cable box. The other thing to check is to make sure that you have the proper input selected on the tv. If you have cable in Video one for example then you need to have your TV input to video one.
My RCA 27V412T TV turns the screen red
Can you see a picture at all or is it completely bright red? Is there sound?
Screen is black, no picture or audio
Give me a model number so I can at least make an informed guess or suggestions.
NO POWER
Need to know how many times the led is blinking.
Re: tv kdl-55ex620 red light blink 8 times Do a Power Reset. 1. While the TV is off, unplug the power cord of the TV from the electrical outlet. 2. Let the TV remain without power for 60 seconds. 3. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.) 4. Turn on the TV. 5. When the TV powers on and a picture is displayed, reset the TV to factory default settings.
  • If the Reset message does not appear and the TV turns off and on, begin again from step 5.
  • If the standby light begins blinking eight times, return to step 1.
6. After the Reset message appears, allow the TV to reset. Do not press any buttons on the remote control or on the TV and do not make any other adjustments for 1 minute. 7. Unplug the power cord from the electrical outlet. 8. Allow the TV to remain without power for 10 seconds. 9. Plug the power cord back into the electrical outlet. 10. Turn on the TV.
  • The initial setup screen displays if the above procedures were performed correctly.
11. Follow the on-screen instructions to complete the initial set up. 12. Perform a system software (firmware) update.
Was watching recorded events, left the room and came back to a black screen, with no sound....tried unplugging dvr and back in with no luck...changed tvs still same result
christy39467,
When you had the black screen on your TV, did you have a banner on the top of the screen displaying the channel and information about the channel? If so, then unplugging the receiver from the electrical outlet for 10 seconds and plugging back in will resolve that issue.
If you had the black screen without the banner, it is a different issue. Please let me know if you had any other messages on your TV screen (No signal, weak signal, etc.).
Ray Calo
DISH Network
1helpful
My 42" flat screen RCA t.v. won't turn on?
I find that if you unplug the cord from the connection to the TV and not the electrical outlet that it should work again but will happen often after. So far everytime I've tried this it works. Hope this helps you out!
Black Spots
Resetting the TV
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Hope it may help you;
Regards,
VOTIT
RAC TV When I turn it on the red light starts to blink and then the light goes completely red yet the screen is still black. I can not turn it off. there is no picture but due to my sterio hooked up to...
Good Day, msteaz;
Not sure what the light is doing but try to reset the TV by unplugging from the A/C outlet for 5 to 10 minutes. If no fix come back with Model & brand.
Good Luck, big Irish.
Rafael
Good Day;
This is very odd for having only have of your picture scanning. Let me ask you a couple of questions:
1. Have you tried rebooting the TV by unplugging it from the a/c outlet for 4-5 minutes, plug back in a/c/
2. Have you moved your TV recently; maybe broken mirror?
Please try and let me know if I was any help; Good Luck, Big Irish.
Tv does not turn on
You does not mean about picture clarity before this problem occurs. Former the picture clarity is well and good means picture is not problem. There is a problem in horizontal deflection area.May be flyback transformer failure shows these type of problem. This service should be done by technical persons only.
Top Soyo Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Soyo Televison and Video Expert? Answer questions, earn points and help others
