20 Most Recent
Mitsubishi WD-52628 52" Projection HDTV Questions & Answers
Error code 13 on mitsubishi wd52628
wait for the light to go out then press power. Then if it doesnt power up hold the menu and the Device/input buttons on the set both in together for 5 seconds the light will blink a series of blinks pause briefly then blink another number of blinks then pause then it will repeat the same two digit blink sequence a few times . Let me know the two digit blink sequence.
52" DLP - TIled Picture
There is a simple tilt adjustment for this set if we could get a e-mail adress will send it to you
I got a replacement lamp for Mitsubishi WD-52628.
Hi,did you close the door cover? Reset the lamp
timer? you can do this by unpluging the set for 5 min
and plug it back(works for most sets). Check the fan
was running ok? You can clean it w an air pressure
can. If you heard clicking or like wanting to turn on the problem could be with the board that powers the lamp.The board it's called the ballast.If its not able
to provide the power to the lamp it will not turn it on and the red light will blink.
Wd-52628 flashing blinking light
Using your original remote, power on the tv, enter "menu 1,2,3, enter" to "Initialize" the "factory reset" once the window comes up choose to reset to default. That should fix the blinking green timer light.
