I didnt turn my computer on for 4-5 months. when I did, a black screen with a big red toshiba came up and the next thing was enter password. I am pretty sure it said bios password, but not positive. I entered the only passwords that I ever use, it wasnt any of them and then it said system is disabled. Now I turn it on and nothing. black screen, the fans turn on so I know somerthing is working. Please help!
SOURCE: default bios password toshiba satellite a135-s2276
I have a Satellite A135-S2356 that had the same problem. I tried the solution from PCTServices above and it worked great.
"Power unit off. Disconnect AC power. Remove battery. Remove the memory cover screw, memory cover and the memory modules. Peel back mylar from JOPEN1 solder pad. Short JOPEN1 solder pads for 30 seconds. Replace mylar. Replace memory modules. Replace battery. Power up unit. If all is well, replace memory cover and screw."
Just short the two little solder pads and it worked great! I thought I would have to send it back to the manufacture but I am back in buisness. Thanks for the help.
Bryan
what you need to do is pull both the laptop battery as well as the cmos battery. in some instances, the battery can be pulled, but on other models, i have seen the battery as an actual physical part on the motherboard or somewhere where it is not easily accessible, in which case you need to clear the cmos by using a jumper on the motherboard, since it is a laptop, they are all different. you may need to see if you can locate a copy of the motherboards schematics and go from there.
Some Toshiba's can be convinced to bypass the startup BIOS password if
you hold down the <LEFT-SHIFT> key while booting the system.
Did you get this from another person or business?
Either way there's a way to get rid of it.
Let me know
comier957
the best thing is to do the system recovery process ..
FOR TOSHIBA A100/135 BIOS PASSWORD
It
