20 Most Recent Toshiba Satellite A135-S2266 Notebook Questions & Answers
The battery on the motherboard needs to be removed and the board will drain. Leave it ten mins and refit battery. It will let you into the bios where if you want you can input the password you want.
Toshiba... | Answered on Aug 13, 2017
I can't find a decent manual for your laptop but there will be 2 pins on the motherboard that will say BIOS Clear. Short these 2 pins and turn the computer on. This is the only way to bypass the BIOS password. This operation will clear the BIOS and reset to factory defaults. After the BIOS is cleared, turn the computer off and take off the short.
Toshiba... | Answered on Mar 26, 2015
The battery may have a higher capacity. I suggest you contact the supplier to check the differences and whether it will fit your model laptop.
Toshiba... | Answered on Dec 05, 2012
Need more info. It does not boot? What does it do when you re boot? Be as specific as you can.
Toshiba... | Answered on Nov 01, 2012
Check to be sure there is enough hard drive space first. If there is plenty, then you could be missing a driver or the install file itself. Microsoft has the installer and drivers you would need if that is the case.
Toshiba... | Answered on Aug 06, 2012
Check to see how much space you have on the hard drive first. If there is plenty you could be missing a driver or the install file. microsoft has the files you need if that is the case.
i tried to use google translate to understand your question but it didn't make any sense either, can you go to google translate and type your question in your native language and convert to english?
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Toshiba... | Answered on Jul 23, 2012
Depends on the model, older toshibas you need a jumper plug.
newer ones may need the motherboard reset by toshiba for a fee.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Toshiba... | Answered on Oct 21, 2011
the drivers should be in your system software only if you are running windows XP go to your control panels folder and click on add/remove.
Toshiba... | Answered on Jul 14, 2011
nothing wrong with your laptop.your internet speed must be slow to support video playback.
talk to your internet service provider.
good luck
Toshiba... | Answered on Jun 24, 2011
Could be a virus, especially if you obtained this from an unreliable source (we have all done it)!
I'd first of all download this little programme, free to home users and very very good.
http://www.freedrweb.com/cureit/?lng=en
Install to a USB pen drive or similar, boot the laptop in safe mode and run it. Once run and any virii found are deleted, run again setting the scan path to C:/.
Check and kill any virii found
Now delete your sytsem restore points ( the viruses if found will be backed up there).
Reboot and you should get into normal boot
If the above fails to fix this, (ie no virii found) the programme you installed has damaged your settings. In which case, first of all, go to MY Computer / Right click on hard drive/ properties / tools and run a disc check on reboot
Reboot and try again
If that fails, you will need to install the OS and do a repair
If THAT fails, you will need to do a full install
Toshiba... | Answered on Mar 29, 2011
FOR all satellite A135-S2266 users,
The drivers download link in previous pages is invalid.
I searched somewhere else and finally found all drivers.
NO MORE unknown devices.
" Then, nothing more just than to share drivers with all!"
this is the new link,
http://www.megaupload.com/?d=KLMIAL9M
The package includes:
Video - Radeon Omega Driver
Audio - Realtek xxx
South Bridge - ATI Catalyst (SM bus driver)
Modem - Toshiba Software Modem Driver
Direct application launch button: get rid of the two unknown devices.
PS: For the 2 unknown devices, just
go to device manager,and update their drivers from list, then search the location of the Direct application launch button, click ok, done.
although this driver works for both,you still have to do it individually.
Toshiba... | Answered on Mar 10, 2011
Try pulling the battery out and power it on with on the AC power plugged in.
Toshiba... | Answered on Feb 28, 2011
Download windows password removal tool 3.0 and follow the instructions. It's just a few steps.
Toshiba... | Answered on Feb 25, 2011
run it under f12 command.
Toshiba... | Answered on Feb 13, 2011
Toshiba Satellite A135-S2266 Notebook Logo
75 questions posted
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
password phoenix bios toshiba satelite
  • Computers & Internet
