Many models of the GE microwave have sensors that can detect humidity
from the foods you are cooking. This allows the microwave to make
adjustments to the power levels used to cook your food. If "Sensor
Error" appears, you should either press "Clear" to cancel the mode or
leave the food in the appliance longer to give the microwave more time
to detect the food.
Press "Time Cook" to manually enter the time
if you receive an error message when trying to use the "Sensor Reheat"
mode of your GE microwave. The error message may be caused by the food
item being too large or too small to detect.
these are some other code error that will help you in case of next time.
Step 1
Press "Off/Cancel" (or "Cancel/Off" depending on your model)
to clear the error code. Note the code if it reappears.
Step 2
Replace the touchpad if the code displayed is "F0," "F7" or
"F10." A function key is stuck or shorted.
Step 3
Replace the touchpad or the clock (ERC) if the code "F1" is
displayed. Disconnect the ribbon connector to the touchpad. If no code
is displayed after an hour, replace the touchpad. If the code displays
again, replace the clock.
Step 4
Replace the oven temperature sensor if "F2," "F3" or "F4" is
displayed. "F2" indicates the oven temperature is too hot and the oven
temperature sensor is suspect. "F3" or "F4" indicates the oven
temperature sensor or shorted or open.
Step 5
Replace the ERC if "F5," F6" or "F8" is displayed. The ERC is
the main control unit. "F5," F6" and "F8 are codes that indicate
problems in the ERC functions.
Step 6
Inspect the door-lock assembly and circuit if "F9" is
displayed. The door must lock when the oven is in use. If the lock
mechanism is not functioning or if the detection circuit is
malfunctioning, the stove will display "F9."
jQuery('.article ol .image').each(function(i,e){
var $this = jQuery(this);
$this.find('img').error(function(){
jQuery(this).remove();
$this.remove();
NOTE:
"F3" codes mean your oven temperature sensor has failed or shorted out.
The only thing you can do is to replace the sensor.
Take care.
How can I fix this problem - should I just throw it away?
