The WPS LED on my router is solid amber
SOURCE: i need to add wps client to my pc
The link below shows you how, to do this with another type of router, BUT the theory is the same for yours. kb.netgear.com › Home › KB
SOURCE: no wi-fi signal transmitted
There is a reset button in the back of your router, which will reset it to all default settings. Try this to get the router to work.
Also is it hard wired into another computer? Check it out that way. make sure the router is working.
good luck
SOURCE: Does my WRT160N have a
The Linksys WRT160N has WPS (Wi-Fi Protected Setup). If you are using WPA-PSK encryption (recommended), then you can easily connect the C4780 to your wireless network using WPS: 1) On the Linksys router, press the WPS button that is top of the case just under the Cisco label. When the LED on the button starts to blink, then the WPS process has started.
SOURCE: hp printer says to press the WPS button on the router. What's that?
SOURCE: Does the linksys-G support WPS or AOSS?
Good question, I have the same router & Brother HL-2280DW and ran the printer setup CD from Windows XP SP3 via temporary USB connection & it seemed to work. The WAN report on the printer itself says OK, however the computer can't seem to find the printer "No devices could be found on the network." I let setup make changes to Windows Firewall, not sure about Microsoft Security Essentials however. This seems like a nice printer/copier at a nice price but this setup is frustrating! PS If it's a security issue I'd like to say thanks to all the hackers for ruining technology for everyone, your junk is responsible for slowing down & complicating computers & technology in the world. Someone please do everyone a favor & start making antibodies that *kill* viruses & spyware & spam and clean & speed things up for a change! All these villians - Where are the cyber super heroes????
