Not reading any cd format
Hi i have just been able to sort this problem, if your system says "NO CD" after it is inserted then the CD is not sitting right inside, solution for this is, join the philips club (free) and update the firmware and update the Gracenote software
1, insert the cd so it is in then turn it off and unplug then take another cd insert it in slowly to push the other one down a bit until it stops (may only move a couple of millimetres, you are only using the cd as it fits the slot so don’t try and insert it!!) plug the centre back in and turn the centre on, it will boot back up and eject the cd that’s still in, wait until it is fully booted and insert the cd again, that should work
OR
2, insert the cd so it is in then turn it off and unplug then you can open the product and physically push the cd down (be careful when you take the lid off as the cd will not be fully slotted down and there are a couple of cables that can pop out but they are easy to put back and obvious) Put the lid back on and plug the centre back in and turn the centre on, it will boot back up and eject the cd that’s still in, wait until it is fully booted and insert the cd again, that should work
any probs just mail back and ill help as much as i can
