20 Most Recent eMachines ET183105 PC Desktop Questions & Answers
How do i factory reset my desktop i forgot password
If you forgot your Bios password then open the pc and reset the COS jumper. If forgot your Windows password then restart your computer press F8 . select Safe Mode and try administrative login to reset password. If you forgot the administrator password then use any third party software like Hirenboot to recover it.
1/25/2015 7:13:33 AM • eMachines... • Answered on Jan 25, 2015
Hooking up a Internal Hard drive
You probably need to give more details. If it's a replacement drive, did you reinstall Windows from a CD? Did you copy from the original hd? It's simple enough to remove the two cables from the original drive, physically remove and replace the drive, and hook up the new drive. But then you'd need to boot to a Windows CD in the CD/DVD player to format and install Windows, if that's what you're attempting to do.There's possibly a recovery partition on the old drive )or a recovery CD). If so, you'd connect the new drive to a second power cable, and data cable (which might not be included in the tower) :(from http://support.gateway.com/s/Manuals/Desktops/8510406.pdf)To restore system software from the Recovery discs:1 Insert the Recovery disc #1 into the CD or DVD drive.2 Restart the computer, then press and hold R when prompted to display the restore process options. The Options menu appears.3 Select a restore process option:- Press R to boot from the hard drive recovery partition or CD. If no recovery partition is found, go to Step 4.- Press F to format the hard drive and perform a full system recovery, then go to Step 5.4 Click a system restore option. For more information, see "Restoration options" on page 5.- Non-Destructive System Restore (Recommended)- Full System Restore (Destructive)- Full System Restore (with Backup) (Advanced Option)5 Follow the on-screen instructions to complete the system software restoration process.
10/29/2013 6:50:52 PM • eMachines... • Answered on Oct 29, 2013
Is getting no signal to the monitor
if the monitor light blinks remove ur pc cabin and romove the memory card and clean it with a soft clean cloth insert it into the slot if having problemremove it oncemore and restart the computer you hear beeps if you hear beebs switch off and insert the memory in to its module and restart the computer
11/21/2012 3:59:47 PM • eMachines... • Answered on Nov 21, 2012
2answers
ET183105 PC Desktop black screen
Either your monitor or video card is bad. Try connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays and works, then your original monitor is bad. If the Borrowed monitor does the same as your original monitor and does not work, then the Video Card inside the computer is bad.
10/27/2012 7:29:06 PM • eMachines... • Answered on Oct 27, 2012
How to insert cd
the cd in any devides you must insert in the contrary side to the mark example if the mark is SONY this side will be UP. the other side contain the TOK, ( the record or information from any cd or dvd)God bless you
9/28/2012 12:54:29 PM • eMachines... • Answered on Sep 28, 2012
ET183105 PC Desktop black screen on bootup
do you get any beeps or ... you know what, describe what happens exactly. If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
5/20/2012 10:12:54 AM • eMachines... • Answered on May 20, 2012
I have 2 bays but I don't seem to have disc drives. Can this be or am I mistaken?
For a PC to operate it needs an operating system that it can load into memory (RAM) from a hard disk drive or from a DVD disk drive. When you wrote "I don't seem to have disc drives" What are you referring to?Installing stuff on PCs is easy, just Google what you need to know and keep t it...
5/5/2012 4:22:26 AM • eMachines... • Answered on May 05, 2012
How to disable an onboard video card and install another video card
There should be a jumper on the motherboard OR a setting in the motherboard bios. Try looking through the bios menus first... If there isn't a way to disable, get the model of the main board and look at the jumper diagrams online.
4/24/2012 12:59:40 AM • eMachines... • Answered on Apr 24, 2012
Ask for a password
Forgot Windows password? A Windows password reset bootable disk could do all the job for you, it can reset your forgotten or unknown Windows password safely and quickly without login, you can create a Windows password reset bootable disk with the tool Windows Password Breaker, then use it to reset your password.
12/20/2011 3:08:26 AM • eMachines... • Answered on Dec 20, 2011
3answers
Forgot password
Go to Snapfiles.com download a program to hack into your pc hope you have another till then
11/19/2011 9:18:23 AM • eMachines... • Answered on Nov 19, 2011
I cannot figure out how to open expansion slots in
All Emachines are made by gateway you will find all you need here http://support.gateway.com/us/en/emac/product/default.aspx?tab=1&modelId=1813
6/22/2011 8:41:56 PM • eMachines... • Answered on Jun 22, 2011
How to get back to factory settings
Have you created your Application/driver cd from start, system recovery?
To recover your system from the hard drive:
1 Remove all CDs and DVDs from the disc drives, disconnect all USB devices
except the keyboard and mouse, then disconnect your Internet cable. If you can still run Windows, click Start, All Programs, System Recovery, System Recovery, then click Yes. Your computer restarts, then the System Recovery program starts.- OR -Turn on or restart your computer and press F11 while your computer is starting.3 Insert the Operating System Recovery CD/DVD when prompted. The System Recovery program starts.4 Click a system recovery option:??  Full System Restore (Destructive) reformats the hard drive and restores the system software as it was when you purchased your computer. This process deletes your data files. CautionThe Full System Restore option deletes allfiles on your hard drive except the restorefiles. Make sure that you back up allpersonal data files before continuing thisprocess.??  Full System Restore (with Backup) (recommended) moves the contents of the hard drive to the C:\My Backup folder and installs a new copy of Windows XP. This option saves your existing data files, but all programs must be reinstalled and the program settings reconfigured. You need at least 4 GB of hard drive space to use this restore option.5 Click Next. The System Restore - Format and Recover dialog box opens.6 Click Yes. Files are restored to your hard drive. When file recovery has finished, the System Restore dialog box opens. ImportantAfter you restore your system, it willappear with the same files and programsit had when it shipped from the factory.You still need to download Windowsupdates and antivirus updates to bringyour computer's software up to date.7 Click Restart. Your computer restarts, and Windows finishes its setup and installation.8 Reconnect your Internet cable and all USB peripheral devices. You are done.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
5/21/2011 1:49:53 AM • eMachines... • Answered on May 21, 2011
I need an instruction book
You can download and print the generic user manual (french) in PDF format by clicking this link.
The download file is in .zip format. Kindly extract the PDF file from the zip archive after the download finishes.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
2/24/2011 1:32:26 PM • eMachines... • Answered on Feb 24, 2011
WHERE DO I FINT SERIAL NUMBER FOR DOWNLOAD MANAGER
There is a serial number at the rear of your desktop.
1/4/2011 9:32:50 PM • eMachines... • Answered on Jan 04, 2011
My eMachine won't load the OS.
It could be a number of things, could you be more specific?
12/30/2010 8:38:57 PM • eMachines... • Answered on Dec 30, 2010
Do you know how to
In checking on this BSOD I located this link.
It has a lot of valuable information on these errors
12/26/2010 6:30:27 AM • eMachines... • Answered on Dec 26, 2010
0answers
eMachines ET183105 PC Desktop Logo
Popular Tags
36 questions posted
Top eMachines Computers & Internet Experts
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
E eMachines
  • E eMachines
Most Popular Question
getting no signal monitor
  • Computers & Internet
