SOURCE: Sony Bravia KDL-46Z4500 Captions
Try pressing the 'Display' button on top left of TV remote.
SOURCE: no signal sony bravia to dell laptop
Most laptops have a combination of buttons you have to press on the keyboard to get it to output on the monitor output. Try pressing the FUNCTION KEY or FUNC/FN key usually found in the bottom left hand side of the keyboard. Keep that button held down while press one of the number keys. Usually the number key will have a picture of a TV screen on it. Might be number 8 or 9. Press both keys at the same time a you can switch between laptop screen, Sony LCD or you can have both..
SOURCE: i have a sony pfm-42b1
you should change it from hdmi to cable. You can do it only on a hdmi tv when you do that you can use it for the pfm-42b1e because i had the same problem too. when you plug your ps3 to a hdmi tv you go to settings-display settings- video output settings than you change it to av multi. After you do that you can use it on pfm-42b1e
SOURCE: Sony Bravia KDL-V40XBR1, no picture
You either have failed 24vdc power supply section or failed backlight inverter board, check for 24vdc first, look for caps with leaking/bulging top.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Sony+BRAVIA+KDL+-V40XBR1+
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
SOURCE: Hello My, just bought Sony KDL
I have one of these. It is probably set up for some other program like the HDMI or Input 1 through 5.
You can press your INPUT button, then scroll to the TV function, which should show up on the top.
