20 Most Recent
Sony KDL52NX800 52 in. TV Questions & Answers
Sony kdl52nx800 will not turn on indicator light blinks 5 times
While looking found this:Found this service bulletin for sony KLD KLV40EX600 not austalia model but think KDL will be similar
Model No: KDL-32EX400 KDL-40EX400 KDL-32EX500
KDL-40EX500 KDL-46EX500 KDL-55EX500
KDL-32EX600 KDL-40EX600 KDL-32EX700
KDL-40EX700 KDL-46EX700 KDL-52EX700
KDL-60EX700 KDL-40HX700 KDL-46HX700
KDL-55HX700 KDL-40NX700 KDL-46NX700
KDL-52NX800 KDL-60NX800
SUBJECT: Counter measure for Intermittently 5 times standby LED blinking
SYMPTOM: Customer may report that intermittently after AC OFF/ ON (or
Deep Standby/ ON), TV will shut down with LED blinking 5 times. If set
is placed in Standby, then On, symptom will re occur. If AC is removed,
set will work normally when AC restored
CAUSE: Timing mismatch of I2C communication causes interrupt signal
inside TV. This causes TV to shut down with error 'Standby led flashes 5
times'
SOLUTION: This is a user correctable issue -
Where possible, please refer customer to Sony Website -(or ) and search
for relevant model to download correct update. If the unit is in
Workshop, please perform update as per Instructions.
No power to sony tv
TRY the main power button on the TV itself. if that doesn't work try this web site:
http://www.youtube.com/watch?v=BLkyFXv2-i4
6 blink error
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy.
For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Where can I get a
You can check the internet. (eBay, Shopjimmy.com partstore.com etc)
eBay has some circuit boards listed. You need to get the part number to get right board.
Make sure you get the make and model of the tv correct. You are asking about a 31.5 inch set and calling it a 52 in TV.
Try
www.partstore.com
My Sony KDL52NX800 Shuts down irregularly and
Hi ! I have same problem than you. My Sony KDL52NX800 Shuts down irregularly and turns back on. My store upgraded the firmware to the latest and it still continues. Did it again today and don't know what to do next.
Problem is irregular, store cannot see the problem when it appears and i don't want to loose my TV again for 2 weeks. Did you finally find a solution ? I may call my service store again this week, because my TV is still under warranty...
Your answer will be much appreciated
Bravia/52 has no power
does the power indicator blink?.if no power indicator check for blown fuse first at the power supply board.
Unit hit by lightning. Replaced
How many times does the standby light blink between each pause? Its a self-test diagnostic that will pn-point us to the source of the problem so please let me know.
Standby light blinks 5 times
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
- No video, Power light is on or blinking.
- TV is making a clicking noise.
- TV takes a while to come on
- Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
